Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
Stark7x (08-02-2023)
#1427
#1428
Hey folks, I posted this question over on the iSudar thread as well-- I just read through this whole thing and did a bunch of research but wanted input from people that have tried multiple solutions. I have recently purchased a 991.1 Carrera 2 (first P car!) and was looking to retrofit CarPlay. I have XM and Bose in my car, looking to see what may be the better buy. Is AUX sound quality as bad as they say it is? Is MOST via the Mr12volt the better option, by a margin or by a lot? I'm an audio engineer by trade, looking for a decent solution in both audio quality but also software support and reliability as well.
Another question I have that I don't believe was answered anywhere, currently I have my 'diamond' multifunction button on my steering wheel set up to Skip Tracks. Does this functionality work on any of these solutions?
#1429
I have the isundar unit installed with Bose and the Satellite Radio module installed. I am not an audiophile or sound engineer, but it sounds perfectly fine to me. I am not sure how perfect you want the sound since you have the noise of the road and the purr of the engine present, and I imagine that would override any differences you could discern in the audio. That being said, there are no AUX artifacts like buzzing/etc present in the system. Even when parked, I see no difference between the AUX, BT, or the jukebox when playing the same songs. I tend to listen to electronic music, soundtracks, but not rock/pop.
another note, I swapped in the iSundar system, replacing the Joyeauto system. I think it is better.
#1430
The only drawback or complaint I have is with the MFD or Multifunction Display. Not all the windows/displays work like OE. In my case the Map for Navigation will not display on the MFD, including the Cellular Carrier which I’m ok with since I use WAZE, Apple Maps or Google.
This is the screen I am keen to keep:
Thanks!
#1431
I may have answered my own question. Looking at @chriswit1 's images in an earlier post, he seems to have the Krando running AND all the info I want in the MFD.
@chriswit1 - is my assumption right? If so, this is awesome and I may just have to pull the trigger in this.
#1433
Could you tell me more about the MFD please? I can live without the Nav map (I never use the Porsche Satnav anyway) and the cellular carrier - what I am wondering is if the other stuff shows up on the MFD. For example, I have my main MFD screen set to show Range, Water Temp, Oil Temp, Oil Pressure, Volts, Time and Date. I find this very useful, especially as the analog gauges which show most of that info are hidden by the steering wheel in my driving position. With your Krando unit, does that info translate over to the MFD?
Thanks!
Thanks!
#1434
#1435
Thanks!
Thanks!
#1436
The Krando will display all your vitals like voltage, water temp, oil Temp, oil psi, etc. under the (Vehicle) heading. Under Audio heading just MM/DD/YYYY. Under Phone MM/DD/YYYY. Map heading (No video signal). Navigation heading list last destination. Trip heading same display as before.TPMS heading same display as before. Chrono heading same display and before. G-Force heading same display as before. ACC heading same display as before.
Schorsch (08-10-2023)
#1440
Do it!
