Sponsored by: Road Spy
What did you do to your 991 turbo today?
Old 12-29-2023, 07:18 PM
  #7066
Wayne Smith
Wayne Smith's Avatar
Received 1,210 Likes on 776 Posts
Originally Posted by Foosh
Thanks, Wayne. I have short ramps, but there still isn't enough room for me to use a hammer and drift punch. Looks like it's going to take a lift, which I do not have..
Buy one. In the scheme of things, they aren't expensive. And they even fit in tight spaces. My ceiling is 9 feet after I extend into the rafters. You'll thank yourself again and again!!!
ndfin (12-29-2023)
Old 12-29-2023, 07:24 PM
  #7067
ltcjmramos
ltcjmramos's Avatar
And your friends will thank you, too!
RadarP3C (12-29-2023)
Old 12-29-2023, 07:52 PM
  #7068
Foosh
Foosh's Avatar
Yeah, I should and no excuse to not have one yet. I have an 1800 sq ft. barn w/ HVAC and 16 ft ceilings. It used to house our diesel pusher motorcoach, which we sold last year.
Old 12-29-2023, 08:10 PM
  #7069
Wayne Smith
OK, I'm envious!!!!! Seriously, just get a lift. You've got room so you have no excuse. Thank me later 😀
PS ... mine has the hydraulic ram at the top so there's no cable on the floor. This makes it a lot nicer. Since you have space, go wider and higher.
And pics or it never happened.
Foosh (12-29-2023)
Old 12-29-2023, 10:13 PM
  #7070
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,482 Likes on 931 Posts
I wish I had a storage garage like that when I owned a diesel pusher! I sold mine last month.
Old 12-29-2023, 10:37 PM
  #7071
worf928
worf928's Avatar
Received 1,654 Likes on 1,078 Posts
liftbars (liftbars.com) work well in confined spaces, are much cheaper than a lift, don’t take up room when you’re not using them, and you can use them anywhere with a good flat surface.
I have 6 sets. I do all my work on them including pulling engines (from 928s.)
Foosh (12-30-2023)
Old 12-30-2023, 12:41 AM
  #7072
TXGerman
TXGerman's Avatar
Finished an oil/filter change, installed LN Engineering magnetic drain plug, replaced engine air filter, cabin filters, hood struts, serpentine drive belt, and hydraulic tensioner.
The following 3 users liked this post by TXGerman:
Big Swole (12-30-2023), Foosh (12-30-2023), RadarP3C (12-30-2023)
Old 12-30-2023, 12:46 AM
  #7073
Wayne Smith
Now that is a lift to lust after!!!
Wait, what are you doing with that 2×4? At first look, I thought you had buried hydraulic rams.
Old 12-30-2023, 01:04 AM
  #7074
worf928
worf928's Avatar
And spark plugs?
Also, why’s the exhaust off?
Old 12-30-2023, 01:28 AM
  #7075
TXGerman
TXGerman's Avatar
Originally Posted by worf928
And spark plugs?
Well, as it turns out, it's much easier (maybe required?) to remove the exhaust and engine support bracket to access the hydraulic tensioner. If it wasn't required, it definitely made access much easier, including then installing the new belt and really wasn't too much of a PITA considering the predicted struggle I would have had otherwise.
Plugs were replaced not that long ago by the PO, so no plugs this go around.
Old 12-30-2023, 09:44 AM
  #7076
Foosh
Foosh's Avatar
Indeed, that is a lift to lust after. What kind is it?
Old 12-30-2023, 01:37 PM
  #7077
Foosh
Foosh's Avatar
Very clever and great for tire changes, brake work, etc. However, I hate working lying down underneath a car, but they are a great alternative for a lot of folks.
Old 12-30-2023, 01:58 PM
  #7078
worf928
worf928's Avatar
And I cannot work under lifts for more than a minute or four.
My shop has in-ground radiant so, in the winter next to the floor is very cozy.
Old 12-30-2023, 02:08 PM
  #7079
worf928
worf928's Avatar
WSM says to remove the y-pipe assembly. It has some very specific directions on how to bend and twist the belt to clear the exhaust and other brackets.
I just did the belt on my wife’s 991S. The only hard part was getting the spacer back in for the 155mm (IIRC) rear bolt.
My TT will get new belt (etc.) next Spring. And PDCC bottle and other bits that are on the schedule.
Old 12-30-2023, 02:10 PM
  #7080
Foosh
Foosh's Avatar
Smile
Now that's a great point . . . your solution is much better for napping and relaxation.
Quick Reply: What did you do to your 991 turbo today?
