VW/Audi 07K (2.5L 20V I5) Swap Thread
Old 08-16-2021 | 04:03 PM
  #2416
hinton's Avatar
hinton
Originally Posted by Pdh
Man a 944 with 1000hp, thats gonna be some startrek **** lol.
How much electrical power can the ecu give to the fuel pump? The fuel pump I need requires a little more juice than the bosh 044. I would need something that can flow over 74gph at 58 psi. I was thinking of running something like the holley dominators. Its 2 pumps in one housing. one pump is used for cruising and the second turns on under load. Would it be compatible? I'm also open to suggestions.
We are actually pulling power from the relay that comes in the PE harness. The 044 runs about 15 amps and that isn’t an issue. I’d have to check the relay to see what it can handle but you can always bypass that one and run multiple for whatever you need.
Old 08-16-2021 | 04:26 PM
  #2417
Sixline's Avatar
Sixline
I took a chance and got the 0280158040 injectors from here: https://www.ebay.com/itm/16381696451...4AAOSwza9gBuE9 Cheap, pretty fast shipping, and they are genuine!
I got these top hats with filters to extend them to standard (48mm) length: https://www.ebay.com/itm/12342057078...IAAOSwiqdbwBJa
Old 08-16-2021 | 04:29 PM
  #2418
hinton's Avatar
hinton
One thing to confirm is the spray pattern. If they are the dual pattern like the 911 turbo injectors you will need to clock them different from what the factory rail allows. The IE rail lets you clock however you want. Just a PSA.
Old 08-16-2021 | 04:33 PM
  #2419
Sixline's Avatar
Sixline
They are conical spray according to the Bosch spec sheet: https://www.bosch-motorsport.com/con...alve_EV_14.pdf
Edit: Also, EV14 doesn't designate connector type, you can get EV14 injectors with various connector types. 0280158040 injectors use TE/AMP Junior Power Timer connectors. Stock 07K injectors are Sumitomo I think.
Old 08-16-2021 | 04:49 PM
  #2420
hinton's Avatar
hinton
Sorry, the harness uses the stock 07K connectors. You are correct in that they are Sumitomo.
Old 08-16-2021 | 05:48 PM
  #2421
Pdh's Avatar
Pdh
Have you had a chance to test them out? At that price it looks almost too good to be true!
Also would this work to connect it to the pe wiring harness?
https://www.fiveomotorsport.com/ev14...eless-adapter/
Old 08-16-2021 | 06:50 PM
  #2422
Sixline's Avatar
Sixline
I still have a ways to go before I have a running car. I am using a Link G4X FuryX with a custom harness that I still have to build. Everything about the injectors looks genuine though compared to knock offs I have seen.
Those adapters should work if you use injectors with USCAR connectors. Again, EV 14 doesn't designate the connector type. 0280158040 EV 14 injectors use TE/AMP Junior Power Timer connectors, sometimes referred to as Jetronic, EV1, Mini Timer.....stupid confusing. I would skip adapters and just re-crimp the proper connectors on. https://www.ebay.com/itm/20224671126...QAAOSwqjJZdrpq
Pdh (08-16-2021)
Old 08-16-2021 | 07:04 PM
  #2423
Pdh's Avatar
Pdh
I like that Idea much better!
Sorry for being the guy who asks a million questions but do you have any preferences wether it be brand, model or configuration of fuel pressure regulators.
​​​Trying sort out the fuel system so I can buy it all at once.
Thanks!
Old 08-16-2021 | 07:55 PM
  #2424
Sixline's Avatar
Sixline
Thanks!
Brand is subjective. You will need a return style with a boost reference. I used Fuelab for my pump, filter, and regulator(53501). Boost Brothers used an Aeromotive regulator and a Bosch 044 pump I think.
Old 08-16-2021 | 08:05 PM
  #2425
hinton's Avatar
hinton
Thats correct. Just stick with name brand stuff and you’ll be fine.
Pdh (08-17-2021)
Old 08-17-2021 | 01:37 PM
  #2426
Pdh's Avatar
Pdh
I have decided to go with a fuelab fuel pump so I can get variable pump speed for longevity as this car will be both a street and track car. Does the Pe 8400 ecu/wiring harness have pulse width modulation to control the fuel pump speed? Or will I have to run the compatible fuelab prodigy regulator to control the fuel pump?
Old 08-17-2021 | 01:46 PM
  #2427
hinton's Avatar
hinton
The PE8400 has PWM capability.
Old 08-17-2021 | 02:07 PM
  #2428
Pdh's Avatar
Pdh
Awesome!
thanks for the info!
One Last question, what would be a good way of setting up engine knock control? Correct me if I'm wrong but the ecu doesnt have this capability out of the box.
Old 08-17-2021 | 03:53 PM
  #2429
Sixline's Avatar
Sixline
Awesome!
You would have to run some sort of external knock monitor and feed that into the PE8400 to retard ignition timing. Mike(@hinton) would have to confirm if that is possible though.
Or choose a different ECU that has it built-in.
Old 08-18-2021 | 09:34 AM
  #2430
hinton's Avatar
hinton
Thats correct. We use an external monitor for tuning and track testing. Once the tune is set we longer run one.
Quick Reply: VW/Audi 07K (2.5L 20V I5) Swap Thread
