VW/Audi 07K (2.5L 20V I5) Swap Thread
Old 08-10-2020 | 07:39 PM
  #2206
alxdgr8's Avatar
alxdgr8
1st Gen TSFI 07k were DI only (Found in the Mk2 TTRS). Iroz made a billet lower intake manifold that added port injectors.
2nd Gen 07k 'Evo' were DI + PI (Mk3 TTRS/RS3)
hinton (08-10-2020)
Old 08-10-2020 | 08:38 PM
  #2207
Tignition's Avatar
Tignition
6th Gear
Originally Posted by Jesse Templeton
I have one coming in a container due in on the 19th. I can let you know how much it cost to be shipped over when I get the invoice.
to New Zealand? Mad!
Are you doing the swap into a 944 then, or is this for another build? Would be very keen to hear what you've got planned and compare notes.
Dan
Old 08-12-2020 | 11:22 AM
  #2208
Droops83's Avatar
Droops83
Originally Posted by hinton
That wiring harness/ECU setup looks excellent!
The design makes it really easy to wire in additional inputs, and I like that it can send CAN data to their dash logger or almost any other brand.
The little power distribution box is also quite slick.
Now, the only question for me is, attempt by register my 951 as a "collector" vehicle in CA, or form a shell corporation in Montana?
hinton (08-12-2020)
Old 08-12-2020 | 11:26 AM
  #2209
V2Rocket's Avatar
V2Rocket
Rainman
Chris,
if you can find property in a more rural county and register the car there you won't get smogged anymore; probably 1/3 of CA requires smog only at time of sale.
they've been cracking down on the MT registrations...
Old 08-12-2020 | 03:29 PM
  #2210
alxdgr8's Avatar
alxdgr8
+1, looks like a great setup! Definitely will be picking one up once I get the 968 into the garage to start work.
hinton (08-12-2020)
Old 08-13-2020 | 03:02 AM
  #2211
Jesse Templeton's Avatar
Jesse Templeton
4th Gear
Dan
Yeah mate its due into Lyttleton. Mine isn't for a Porsche its destined for an Audi CQ. There's just so much useful information here for the engine . I'm always keen to share things I learn, for sure.
The following 2 users liked this post by Jesse Templeton:
hinton (08-13-2020), _0000_ (08-17-2020)
Old 08-13-2020 | 01:50 PM
  #2212
Nowanker's Avatar
Nowanker
From: Formerly the DPRK, now seeking political asylum in Oregon
Originally Posted by V2Rocket
Chris,
Just a matter of a PO box out in the hinterlands somewhere...
Also keeps the CA plate, and stops you from being unnecessarily targeted by the CHP.
I understand that vehicle registrations are their sole source of funding, making them highly motivated to correct 'improper' ones.
"Don't invite the man into your life."
-Somebody wise.
Old 08-14-2020 | 05:52 PM
  #2213
Pdh's Avatar
Pdh
Has anyone compared the before and after weight distribution of the swap?
Old 08-14-2020 | 05:57 PM
  #2214
hinton's Avatar
hinton
Not that I’m aware of. Alan’s car was corner balanced when it had the LS so we can compare it like for like against that. We’d have to get stock info from someone else though. It definitely moves some weight further back, just not sure how drastic of a change it will be.
Old 08-16-2020 | 01:39 AM
  #2215
odurandina's Avatar
odurandina
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Random thought,
Since the 924, Audi 80/Fox/ and VW Golf/Rabbit cars have their
roots in the VW minibus of the late 60's,
Wouldn't this engine be rad pulling a classic VW minibus up PCH
to First Point in the Bu, w/ longboards sticking out of the roof.
hinton (08-16-2020)
Old 08-16-2020 | 04:07 PM
  #2216
Pdh's Avatar
Pdh
Does anyone know the part number for the tt rs crank pulley that fits the 07k or are they all the same? Also I have been looking at purchasing a turbo but have no experience with them. I know I want something around the 58 to 70 Ib/m flow rate for a boosted stock motor with potentially a cam and springs. I have narrowed down my turbo choices to the hx 35, (he 351 cw and ve) and gt3788va. Which turbo would have the quickest spool and will variable geometry turbos work on the ecu? Also will the efficiency of a 70Ib/m turbo over a 58Ib/m turbo offer any benefits? I can't see myself ever pushing more than 560hp and will more likely in the 460-510hp range.
Thanks!
Old 08-16-2020 | 04:09 PM
  #2217
ealoken's Avatar
ealoken
Thanks!
I would go to the modern g30-700 turbo.
Super easy spool and a perfect match for a 07k
Old 08-16-2020 | 04:32 PM
  #2218
hinton's Avatar
hinton
Thanks!
What’s your budget for a turbo? I can help you with the best option at whatever price range you have in mind.
Old 08-16-2020 | 04:52 PM
  #2219
Pdh's Avatar
Pdh
I would like to keep my budget below 800$ unless there is a huge benefit from something more expensive.
Old 08-16-2020 | 05:32 PM
  #2220
hinton's Avatar
hinton
The issue with turbo’s is there isn’t a lot of options in the middle of the road. Here are my suggestions at certain price points.
Under $600:
HX35 w/ T3 .82 Turbine Housing like my video
Chinese turbo, specifically the X series from CXRacing - https://www.cxracing.com/TRB-SGT3076-82-V-RRB
Under $1500:
Garrett GTX3071R Gen 2 - https://www.garrettmotion.com/racing...x3071r-gen-ii/
Borg Warner S300 - https://agpturbo.com/borg-warner-s36...-68-billet-62/
Over $1500:
Garrett G Series, take your pick - https://www.garrettmotion.com/racing...rmance-turbos/
Quick Reply: VW/Audi 07K (2.5L 20V I5) Swap Thread
