Refresh951's Hybrid Ultra Stroker Build
Old 06-10-2013, 01:15 AM
  #601
refresh951
refresh951's Avatar
Originally Posted by Rogue_Ant
The issue is with the main ignition driver not latching 'off' properly. By giving it a little help, and the correct dwell-timing, the HVC-II coil is absolutely fine. The Blaster 2 coil does exhibit a small similarity to the HVC-II effect, but really shouldn't be an issue.
I will update the ignition thread, and my website shortly.
Cannot thank you enough for all your help on this. I appreciate the development work you have done on what I believe will prove to be very effective ignition option for our cars. An option that is very low cost with 3X the energy of the stock setup at redline.
Old 06-10-2013, 11:59 PM
  #602
refresh951
refresh951's Avatar
Got some interesting info today. MSD notified me that my HVC II coil was BAD! They said it could not be repaired and they shipped me a new unit. It is scheduled to arrive tomorrow.
Old 06-11-2013, 12:22 AM
  #603
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Glad to hear they took care of you!
Old 06-12-2013, 10:49 PM
  #604
refresh951
refresh951's Avatar
Finished up the fab work for my 3 inch exhaust tonight. Everything is tacked and I am really happy with the fitment. Tomorrow I will finish up all the welds.
Old 06-12-2013, 10:51 PM
  #605
Paulyy
Professional Hoon
Paulyy's Avatar
I'll give you a tip. Weld as much as you can on the car. Because It'll move and things wont line up.
Old 06-13-2013, 04:12 AM
  #606
Thom
Thom's Avatar
Why? The exhaust line needs degrees of movements to avoid breaking.
Old 06-13-2013, 04:47 AM
  #607
Paulyy
Professional Hoon
Paulyy's Avatar
When welded in place, There would be less movement with the exhaust as it can pull. when doing my Xover pipe and wastegate pipe, we had issues welding it off the car because it just kept moving. We did it on the car and now it fits very well. You weld as much as you can on the car then you can take it off and finish it off and shouldn't move
Old 06-13-2013, 04:54 AM
  #608
Thom
Thom's Avatar
Sorry I had understood you meant welding everything onto the car....
Old 06-13-2013, 05:52 AM
  #609
Paulyy
Professional Hoon
Paulyy's Avatar
All good mate, You and I know what would be a silly thing to do.
Old 06-13-2013, 01:13 PM
  #610
Crazy Eddie
Crazy Eddie's Avatar
We all know Paulyy is crazy ... but not that crazy !!!
Old 06-13-2013, 02:02 PM
  #611
CyCloNe!
CyCloNe!'s Avatar
That baby sounds awesome Shawn, can't wait to hear it with the new exhaust setup.
Old 06-14-2013, 07:45 AM
  #612
Dutch944
Dutch944's Avatar
I totally agree! Did the same thing on my old exhaust and that went perfect! We've tried it out on other cars by welding it on the ground but we had to redo it all the time..
Old 06-16-2013, 04:25 PM
  #613
mtnman82
mtnman82's Avatar
Knowing how quick you are Shawn I'm thinking this is moot, but I had a similar experience with a custom exhaust on an old Datsun. Trying to weld it off the car had the guy taking it off again and putting it on a bunch of times. I suggested doing it on the car and it went a lot smoother. Also, I bought a used custom exhaust from Lart quite a while ago which was welded on his car. I couldn't believe how perfectly everything lined up when I put it on my car.
Old 06-16-2013, 04:54 PM
  #614
Tom M'Guinn
Tom M'Guinn's Avatar
Anyone ever fry the DME or other electronics by welding on the car?
Old 06-16-2013, 07:16 PM
  #615
Paulyy
Professional Hoon
Paulyy's Avatar
Never,
I always clamp the the clamp as close to what i'm welding, on what i'm welding. And to disconnect the battery
Quick Reply: Refresh951's Hybrid Ultra Stroker Build
