Since everyone else has a V8 build thread...
#151
Sean,
Ans#1 That is exactly what I am doing. I will be building something that looks like the Kolken which raises the Rear arm mounting points. I will be raising them the exact same amount as the front. So, you nailed it. In the same action, I'm hoping to lose another 10-20lbs off the car.
Ans #2 I will probably be going with Moton adjustables. My travel with be something like Patricks. Very short.
It is all a compromise. No doubt. My only advantage is that I know what handling traits I favor in my driving style and will be able to compromise in that general direction.
From a little bit of experience, depending on how low the front is, you will need to use camber plates that are raised up through the shock towers. such as the Racers edge ones, and i believe Kolken use to make them. we found that with the KW's anything more then 1 inch lowered then stock we would hit the bumpstops on the track through a corner or braking. This was with the KW flat camber plates. Changing them for the Racers Edge ones fixed this problem. KW have almost the same shock travel as the Motons so i would believe the RE camber plates would be needed. Or in your case im sure you can fab up a set to suit your needs.
Sean
#153
Walk it off Patrick, get your *** back out there. No worries. The Moton's will be custom for my height. I have learned much from your posts. Thank you for those.
Thank you for that info Sean, damn good to know. There is a lot of useful stuff you guys are spitting out. I love it.
I don't think it will ever get below 2200lbs. So it will be very light, but certainly not the lightest. Definitely one of the stronger power to weight ratios though.
Sounds awesome Bruce, i cant wait to see what you come up with for the rear. You may have the record for the lightest 951 when your done.
Sean
Sean
#154
I like this thread because it is really a concatenation of ideas from all the other heavy hitters out there (Patrick, Tony, Jet, etc) and allows us to answer the question: "If you could do anything you wanted with the 951 while keeping the 'essence' of it, what would you do?"
Being a suspension nerd I take particular interest in mucking/enhancing the Mac Strut and trailing arm but the thread is also making me appreciate how much i want to weld stuff again...
#157
Damn good to have you and anyone else who wants to stop by. Thanks for the ride in the Lotus!
#159
Got this sweet little puppie in the mail today. I still have the intake and headers to make. A bunch of plumbing etc. But this was a large step in the right direction. I can now confirm my engine mounts will work and other finishing touches can happen. More to follow in this thread when I'm near the very end of the project.
#160
Rainman
Tube looks great, good idea on that strengthening ring.
Re: Kokeln-style rear suspension, think there'd be any advantage running a round tube versus a square/rectangular? My thoughts lead me to prefer the round, as a rectangular tube makes me think of a warped 2x4 - whereas a cylinder won't warp under torsion. Also would need to know how thick the original torsion carrier was to decide what wall thickness...the guys at the metal store down the road now know me by name...
#161
If you take a look at more complex tube forming processes (which usually involve more complex steels/metals), there is often a hot-forming process or post-processing heat treating that takes place. Depending on the heat treating performed, we have the option to make the material more homogenous and the crystal structure more uniform. This would effectively then make our square tube slightly stronger than its round counterpart.
The only difference is that with a square tube you can actually see how the metal is twisting, whereas it's less obvious with a round tube.
In the majority of applications, the square vs. round debate is purely academic. One is usually used over another as a matter of convenience/aesthetics. For example, when I build a tube frame for a car, I often start with square tubing as the base, so as to help prevent my assembly from rolling away!
#163
No advantage with the round as the fabrication would be a little more difficult and it should not sag due to the tabs they have welded in that bolt to the chassis where the nice aluminum cross brace bolts to. I don't think you have to go very thick on the wall. - And everything Mr. Aussie said. - I truly learned quite a bit there.
