Porsche 944 Turbo restomod
#256
Tomorrow I can start the engine again and check for oil leaks.
For now some pictures of the AugTronic ECU install:
MAP sensor on the right and EBC on the left:
Temperature sensor in the intercooler piping in front of the throttle vavle:
Wated spark ignition coils:
AFM replacement pipe:
Modified ECU (AugTronic ECU):
All installed:
All installed:
#257
In the UK at https://www.partsforporsche.co.uk/55-augment-automotive.
I do think Lindsey Racing can supply AugTronic parts.
#258
Nice build!
Curious, what are the things in circles?
Wouldn't it be better to have the fuel hose arrow is pointing to, up higher away from heat, headers, etc.?
#259
Green circle: brake wear indicator and abs sensor wiring. I have removed the ABS system and the brake wear sensors. To remove the brake wear sensor light on the dash I have shorted the wiring which is seen in the green circle.
The fuel lines are covered in a heat shielding and I did route the line along the fuel line and then strait to the hole in the body.
#260
#261
Not sure they sell it seperately (they don’t for the Tial wastegate adapter plates). Just send them an email.
#262
I think I have found the problem causing the oil leak.
The inside of the (ofcourse brand new) cam shaft oil seal did not had a good seal to the spacer sleeve.
I have ordered a new spacer sleeve and a new seal and have to wait again :-(
But, pretty confident that this will solve my oil leak!
#263
Engine bay looks great, congratulations.
Almost there!
Almost there!
#264
It's definetely the camshaf seal!
In the early days the oil seal was a 47-30-7.
Nowadays you will receive a 47-32-7 oil seal when ordering a new camshaft seal. However, my spacer sleeve has an outer diameter of 30 mm. The 32 mm seal will never seal!
#266
in a few weeks I can tell you if it is a good fit.
333pg333 (06-11-2020)
#268
333pg333 (07-21-2020)
#270
Just a quick (pictureless) update:
I had the car running, but heard a knocking sound coming from somewhere near the transmission tunnel. At first I ignored it, because I thought it was the exhaust hitting a bolt in the transmission tunnel. It turned out to be the reference sensor marking on the flywheel touching my brand new reference sensor. I had gapped the sensor bracket with an old sensor while using a 2 mm spacer ring for the speed sensor. Why did I use the 2 mm spacer? Because it came with the car! Using this spacer resulted in a perfect gapped speed sensor, but a reference sensor mark just hitting the reference sensor.
After regapping the sensor bracket the car did not start.
Retried --> No start
FYI: retrying meant
- taking of the intake manifold
- removing the sensors
- loosening the bracket
- putting in the modified old sensor (with a 0.8 mm ring attached)
- fastening the bracket
- removing the old sensor
- inserting the sensors
- re-assamble the intake manifold
I did that several times with no luck!
This week I received a brand new sensor bracket en two new sensors and while regapping the bracket noticed a minor coolant leak from the heater valve. I have probably wrecked the heater valve with all the fooling around with the sensors. Now I'm waiting for a new heater valve. I will have to drain some of the (Evans waterless) coolant to don't make a mess replacing the heater valve.
If the car won't start in the next couple of days I probably will take the engine out and go for a LS swap!
All nightmares on working on an 944 Turbo engine are coming back to me from a distant past.
FYI: retrying meant
