928s for Sale
#7802
#7804
#7806
#7807
#7808
I'm selling a 1983 Porsche 928s that I had previously restored for my daughter. You can find all the information on the build at the following links...
https://rennlist.com/forums/928-foru...other-day.html
https://rennlist.com/forums/928-foru...n-83-928s.html
https://rennlist.com/forums/928-foru...up-holder.html
https://rennlist.com/forums/928-foru...-fixed-it.html
https://rennlist.com/forums/928-foru...1983-928s.html
He is the story, around March-April of 2017, my daughter's senior year, she wrecked the car. Accelerated in the rain from a stop sign, spun it out, slide it down a ditch, and t-boned a tree on the driver's side a pillar. She was OK, but the car, I assume, is totaled although I never had it looked at since I only had liability (bad call). I had the car pulled back up to the road and I literally drove the car home with no issue and the AC was still working. Car actually drove straight so there was no noticeable issue other than the obvious fact the door was caved in along with the a-piller. The car was parked in my garage since the accident and I made the decision a few weeks back to get it gone.
It took 2 days, but I removed the door in pieces and saved everything that was still of value. I had to cut the lock on the trunk using a sawz all to get it open. Hood was bent so it was removed and tossed in the trash. I invested about $4500 in this car and did 100% of the work myself. The links above show all of the work I did including rebuilding the engine and updating some of the parts. The car fired right up after sitting for 1.5years and does not drop or burn any oil. Please read through the 1st thread link above as that has about 95% of everything I did to the car. I purchased all of the parts from Roger@928RUS and have all the receipts.
If you have a 928S that needs help I envision you buy this car and swap everything over and you will be ready to go. The suspension was all redone recently, tranny shift kit, fluid change, Dash Pod has Roger's printed circuit board upgrade with my own LED upgrade.
Below is a link to two videos I took today.
Video 1
Video 2
I don't prefer to part out the car so I am looking to get $3500 as is, but open to reasonable offers. Send me a PM if you have any questions or interest.
Video 1
Video 2
Engine: I replaced ALLgaskets and orings on the engine except the head gaskets and have all the receipts from 928RUS that I can provide. All work was done by me. Porken tensioner as well as the heavy duty silicone oil pan gasket. The engine fires up with good oil pressure and does not leak or burn any oil.
Dash Pod: Upgraded to the 928RUS circuit board and did my own DIY upgraded LED's that are much brighter. Did the speedo plastic gear upgrade and covered the prisms with the reflective tape.
Suspension: Replaced the bushings and struts on all 4 corners and probably has less than 500 miles
Rims: Not the standard rims and they look really nice, but one needs straightening, which I can have done local.
Alternator Upgrade 100amp GM, Fixed Fuel sending unit to accurately read, replaced steering rack boots, delron rack bushings, good wiring harness, AC lines were upgraded to R134a compatible along with dryer and new orings, rebuilt AC compressor and was working even after the wreck. Auto trans works flawlessly, upgraded valve body springs and replaced filter along with new gasket, brand new custom SS brake lines, power seats still work.
PM if you interested in any of the parts or the whole car. It is perfect for someone that wants to swap over everything so you have a car that can be driven. I am also open to purchasing a good 928 that is compatible with a 83 928s.
BTW, this is how nice the car was before my daughter wrecked it.
Other random pics
#7810
https://bringatrailer.com/listing/1985-porsche-928s-37/
#7811
A new one up now. Pretty nice too. '85 5-Speed Prussian Blue Metallic over Burgandy with 82K miles. No rubbies, original radio, LSD, seats pleats looks tights, drip and jump post cover, air filter on right way up, and Club Sport wheels.
#7812
#7813
I really like this one. '78 Minerva Blue Euro 5-Speed. Looks like Jim D. knows this one. This could be really nice with some TLC.
https://detroit.craigslist.org/okl/c...051464046.html
scoper (01-08-2020)
#7814
islaTurbine (01-09-2020)
