928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 06-16-2020, 01:53 PM
  #8086
aseem
aseem's Avatar
Default Pimping the engine bay
Made a billet aluminum oil-filler cap with 928 logo. Made on a manual lathe, mill and pantograpgh (logo).
The following 8 users liked this post by aseem:
AirtekHVAC (06-16-2020), Big Jack (06-21-2020), Dark shark (06-17-2020), edlocke (06-17-2020), Geza (06-16-2020), just_drive (06-17-2020), placer (06-16-2020), slownrusty (06-16-2020) and 3 others liked this post. (Show less...)
Old 06-16-2020, 02:10 PM
  #8087
slownrusty
slownrusty's Avatar
So awesome aseem!
aseem (06-16-2020)
Old 06-16-2020, 04:50 PM
  #8088
Vipermn1961
Vipermn1961's Avatar
NICE!!!!!!!
t75kjh1 (03-06-2021)
Old 06-17-2020, 12:19 AM
  #8089
dr bob
Chronic Tool Dropper
dr bob's Avatar
The car made it to the lift from winter storage today, to fix a long-time "seepage" problem at the gearbox. If it was a leak I would have fixed it sooner... All cleaned under there, drying now, then drain the sump. Seepage (it's not a leak!) is from the o-ring where the reservoir slides over the tube from the sump, or it's from the reservoir cap. Either way, the reservoir comes out tomorrow for full inspection, cleaning, and some new parts. Then another cleaning before refilling. I may add the dab of Dreibond that GregB mentions on that little shaft end that surfaces by the reservoir. I hate doing hack fixes, but this one comes with the blessings and directions from the Master. Hold my beer!
Old 06-17-2020, 03:18 AM
  #8090
808c2s
808c2s's Avatar
Nice
Old 06-17-2020, 04:51 PM
  #8091
chart928s4
chart928s4's Avatar
Anyone who has this interior color knows the problem of "50 Shades of Porsche Light Grey".
The car is running flawlessly so I've been working on the interior. I DIY recovered the pod last year and it came out surprisingly well. The dash and console recovering is queued up but there were delays so I just started working on the carpet. From upper left clockwise, new DIY right rear footwell, new DIY underseat A/C valve cover carpet, old underseat carpet, various carpet and vinyl swatches for matching, old right rear footwell. Yes that is the actual OEM color on both old and new carpets - Porsche Light Grey/Porsche Raspberry.
2 pieces down, 23 to go.
worf928 (06-21-2020)
Old 06-20-2020, 06:38 PM
  #8092
Geo55
Geo55's Avatar
So my ashtray mounting tabs were broken and the ashtray just rattled around so I thought that I would fix it by J-B welding some aluminum plates under the broken tabs that i could tap. Then I said...."I don't smoke but would like to have an accessory plug". so I bought a set on Amazon
https://www.amazon.com/EEEKit-Charger-Voltmeter-Cigarette-Splitter/dp/B07TFBW482/ref=sr_1_22?dchild=1&keywords=accessory+plug+with+voltmeter&qid=1592688743&sr=8-22 https://www.amazon.com/EEEKit-Charger-Voltmeter-Cigarette-Splitter/dp/B07TFBW482/ref=sr_1_22?dchild=1&keywords=accessory+plug+with+voltmeter&qid=1592688743&sr=8-22
and fitted them to a plate I manufactured with the same spacing as the ashtray mounting holes.Now I also have a digital readout of my voltage, @13.7 volts.
Hey_Allen (06-20-2020)
Old 06-20-2020, 08:50 PM
  #8093
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
Originally Posted by Geo55
So my ashtray mounting tabs were broken and the ashtray just rattled around so I thought that I would fix it by J-B welding some aluminum plates under the broken tabs that i could tap. Then I said...."I don't smoke but would like to have an accessory plug". so I bought a set on Amazon https://www.amazon.com/EEEKit-Charge...688743&sr=8-22 and fitted them to a plate I manufactured with the same spacing as the ashtray mounting holes.Now I also have a digital readout of my voltage, @13.7 volts.
Nice work.
Dave
RSMartin (06-20-2020)
Old 06-22-2020, 07:19 AM
  #8094
ddire333
ddire333's Avatar
Three weeks ago started this ....and yesterday got all this put back together and it still works! Biggest repair I have ever taken on and didn't have full faith until test drive was complete. Couldn't have done it without this forum for guidance. Gearbox was leaking badly from the grate, so that was the focus, but did a lot of the while you in there stuff. Delighted went to plan and back on the road.
The following 5 users liked this post by ddire333:
928 kiln (10-11-2021), Bertrand Daoust (06-22-2020), Geza (06-22-2020), slownrusty (06-22-2020), UKKid35 (06-22-2020)
Old 06-22-2020, 08:30 AM
  #8095
grepin
grepin's Avatar
Impressive. Well done.
Old 06-22-2020, 09:19 AM
  #8096
slownrusty
slownrusty's Avatar
Well done @ddire333 - that's quite an undertaking but so gratifying once its back together and a great feeling of accomplishment. Congrats.
ddire333 (06-22-2020)
Old 06-22-2020, 06:19 PM
  #8097
Geo55
Geo55's Avatar
Been there my friend. did Torque tube bearings and replaced the rubber tranny lines while i was in there. Nice job though. Always gratifying to have it work afterwards and not have extra stuff laying around
Old 06-22-2020, 06:56 PM
  #8098
jej3
jej3's Avatar
Default Nuthin' like Flushin'
Flushed coolant from The Black Witch in preparation for Sharks in the Badlands.
- Drain coolant from one block plug and radiator
- Fill with Tap Water, run to operating temperature and drain
- Fill with Distilled water, open up heater valve, run to operating temperature and drain x 2
- Fill with Distilled water only and go for a drive (not done yet)
One of the block drain plugs is rounded off so I am getting a rounded nut removal tool and new plug later this week. When those come in, plus new Heater Control Valve, I'll do final drain and go back with 60% Distilled Water/40% Porsche Coolant.
Also got the sensor lead for my 3rd (in front of radiator) Fan installed in radiator. This SPAL fan comes on at the higher end of the temperature range and is triggered to turn on whenever the AC is on. This setup should ensure no heat soak from AC in stop/go traffic PLUS heaven forbid the FANs or FAN controls fail, I'll still have cooling.
Old 06-22-2020, 07:49 PM
  #8099
Tony
Tony's Avatar
replaced a couple of missing nuts on my oil pan.
released the front pinch bolt and checked the thrust bearing .. .008 ..replaced with a new bolt and Tqd to 66ftlbs..
while i was down there.....replaced my starter with a used one of an old engine i have. ....my original 200K mile starter was tired and the bendix would drag after starting making an embarrassing noise....... This starter came of a 40k mile engine. What a difference!!!
started diving into my cooling fans....
little bits here and there...
A good day!
Old 06-22-2020, 07:55 PM
  #8100
Tony
Tony's Avatar
i need to add a 3rd fan out here...you have any links..details on your set up.
Quick Reply: So what did you do to your 928 Today......
