So what did you do to your 928 Today......
#7397
unhinged
Cleaned and lubed some hinges
#7398
Use my new cobalt drills on all the seized bolts; front ABS sensors, ABS sensor earth, ignition coil bracket/engine bay firewall bolt.
Full time score - drills/easy outs/taps 4, seized bolts 0.
What a difference cobalt makes!
#7400
Put her on the ground....
#7402
Today was busy, repaired the fiber optics on the AC control, as well as repaired the panel. Disassembled the turn switch to find I'll need a parts switch. Worked on the dash and repaired the broken comb flap. And replaced the defrost vacuum pod.
#7404
DROVE IT !!
It hit 50 degrees today and roads all clear from rain we had couple days ago, so took the cover off, checked tire pressure, oil, etc, and Drove It! Now I can’t wait for spring to really get here.
First drive of the season!
#7406
New fuel lines and new fuel filter. BTW, is that green pump OEM/original?
Attachment 1351356
Attachment 1351357
Attachment 1351356
Attachment 1351357
#7407
Inventor
Picked up my '88 from the body shop.
Fixed some rust bubbling in the driver's door jamb and had them put in a new door handle hinge. (Did not want to do that job again! )
Little things but super annoying when I saw them every time I opened the door.
#7408
Archive Gatekeeper
Yes, green fuel pumps are OEM
#7409
Ever since installing my HID headlights, it has bugged me that the driving lights and fog lights didn't match in color (too yellow), so I ordered some LED H3 bulbs for them and did the install tonight. Now all the front lights match and they're brighter too, even brighter than the KC Hi-Lites 100 watt bulbs I had been running as my driving lights for dark empty roads.
Here are a couple pics after having changed only the Passenger side to the LED with the regular bulbs still in the Driver's side.
and here are some after completing both sides.
#7410
Archive Gatekeeper
Washer sorting:
