So what did you do to your 928 Today......
#7291
Chronic Tool Dropper
Spent a few hours laying on the floor with wrenches, levels and angle gauges getting the alignment dialed in. The front crossmember was out almost a year ago now for engine oil sump gasket, and it got motor mounts at the same time. This is now the second full alignment, as left front lower control arm seems to have moved a little as I added miles under it. Caster had drifted from normal 4.5º to 6.15º just on that left side, adding a little "pull" towards the right. Camber and toe were still perfect, so it seems the control arm drifted forward some; braking normally pushes that lower arm backwards, so this is an interesting change. Nonetheless, it's all good again. I may throw the alignment tools in the car for Sharktoberfest in a couple weeks, in case anyone is interested in seeing how some of it can be done DIY.
The street and driveway are ice-covered this morning. So long as the local gubment folks can resist the urge to put de-icer (salt slurry...) down early this year, the plan is to leave for Anaheim and Sharktoberfest in a couple weeks. There's a good bit of new snow on Mt. Bachelor already. Frozen fingers crossed...
#7293
it sounds very good. The orange lighting matches the dash which is one of the reasons I got it. Need to check if USB charging is possible. It's a good unit which complements the interior very well.
#7295
Hi Ron.
We put our house under contract about 2 weeks ago and are downsizing considerably with kids now out on their own. So I'm losing my lift, at least for the near term.
Now I'm no longer able to put it off until things slow down at the office.
It should be a roller again by Friday. Thank goodness for 3 day weekend.
Still a lot to do. Egads.
#7296
Glad to see that you are ok. Hate you are losing the lift. I am hoping to have mine in a few months.:fingers crossed). Stay in touch.
ordered Noid light set tonight while at airport, then lost my work phone. Pisser.
#7297
Motivated by a recent e-mail from another 928er regarding LED bulb choices for the ashtray backlight, I had my ashtray out anyway and decided to replace the less-than-satisfactory BA7s LED bulb (a Super Bright LEDs model BA7S-W, I think, installed many years ago, and that had a rather narrow beam) with another type I came across on Amazon.com ():
Installed in the socket, it looks like this:
which, in turn, is clipped into the ashtray assembly next to the lighter socket:
It's got a better beam pattern and is brighter than the previous BA7s LED bulb, so I could get rid of a metal reflector that I had cobbled together that focused light on the back of the white plastic disk above the lighter, and also allows a little light to go through the hole in the side of the ashtray and illuminate the interior slightly (as before, with the original incandescent bulb).
The car should be much faster now, I'm sure.
#7299
I retrieved my only 1/4" drive 10mm short socket from under the Intake manifold on my GTS finally. I then used it to tighten the 2 nuts that hold each fuel rail to the engine. Happy days!!
#7300
Finally got around to fixing my headlight issue only the brights would work, so pulled the fender liner and the headlight shield, probably not the right name, anyway found broken yellow wire going to the passenger side low beam, repaired wire and All is well😎✌
#7302
Vegas, Baby!
Got new under carpet padding from Classic 9 Leather, it's going in today.
#7305
Parts Washer
^^^^^^ You're my hero.
Meanwhile, at our place . . . looking over engine grime and contemplating whether a leaky AC compressor sprays oil this way.
I hate grime.
I hate grime.
