928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 06-22-2016, 01:23 PM
  #6436
Pappy
Pappy's Avatar
Default Coils
I'm guessing these were original. Can't see how I was getting any spark from the driver side. Passenger side wasn't as bad but damn was that a PITA to change out.
Old 06-22-2016, 01:48 PM
  #6437
Petza914
Petza914's Avatar
Received 6,603 Likes on 4,198 Posts
Originally Posted by Waldo928
Copied my own key. Sterling silver!
Nice work, but FYI replacement keys can be made from a photo like that, by guys like keys4classics. I'd delete the photo from the post and I didn't include it in my reply.
Old 06-22-2016, 01:54 PM
  #6438
Waldo928
Waldo928's Avatar
Point taken. Thought it would need to be more hi-def to do that, but better safe than sorry I guess.
Old 06-23-2016, 09:06 PM
  #6439
traxtar928
traxtar928's Avatar
The other day I took a video showing the variance in resistance that my original ground strap had. It ranged from 0.4 - 208.4 ohms... yes, you read that correctly. Granted, I could only get that for a fraction of a second, and could almost consider it an anomaly, but there were other 'blips' of over 100 ohms as I moved the strap around... so it's reasonable to assume that while driving the strap would see some resistance spikes that could definitely mess with the electronics of the car over time.
In shorter words... CHECK YOUR STRAP!!
Still have the positive cable, engine ground strap, and engine harness to replace, sitting in the garage.
The video I took covers the original battery strap resistance, my replacement strap I built (Waytek 16" 2 gauge strap and sealing heat-shrink tubing), and then I open up the old strap and show the corrosion at the connector.
Highest resistance reading on DMM was 208.4 ohms!
Old 06-23-2016, 09:58 PM
  #6440
The Deputy
The Deputy's Avatar
Wash day.
Brian.
Old 06-24-2016, 02:37 AM
  #6441
The Forgotten On
The Forgotten On's Avatar
Registered my 89 in my name after buying it. I finally got a chance to head down to the DMV and got special treatment because it was a 928.
I was in and out in 15 minutes. It was pretty great
Old 06-24-2016, 09:43 AM
  #6442
Kiwi'79
Kiwi'79's Avatar
Oh yes!!! Such a simple act!!! However I am with you here, i got such a buzz when I registered my first, well my ONLY dream car for the first time!!! What is it about these cars that has me ( a great MANLY NZ HUNTER well apparently, according to her..) coming across as all mushy...and the like
Old 06-25-2016, 12:23 PM
  #6443
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,320 Likes on 500 Posts
I cleaned (DeoxIT D5) the passenger (right) side air bag sensor connection.
Every now and then, when I hit a hard bump, I get the airbag warning for a few seconds (display AND warning light), and then it goes away.
It can be fine for many days or I can get this warning many times on the same trip. Not a big problem but just annoying.
After looking here for some info, I found this thread amongst others mentioning to start with this.
https://rennlist.com/forums/928-foru...29-3229-a.html
Thanks Ed!
Time will tell if it worked.
Old 06-25-2016, 01:47 PM
  #6444
Jehu Gearloose
Jehu Gearloose's Avatar
Learned to powdercoat . . . poorly, but with great enthusiasm.
Old 06-29-2016, 11:01 AM
  #6445
GeorgeM
GeorgeM's Avatar
Started on HVAC blower motor replacement. Removed the cowl piece and managed to get it out by only removing the two hood hinge bolts and raising the hood a bit. Not to bad a job so far. Greg's new harness is next.
Not much debris at all. The evaporator wasn't too bad either, but managed to vacuum out a little bit of crud.
Old 06-29-2016, 12:23 PM
  #6446
bureau13
bureau13's Avatar
Drove it. Got a speeding ticket
This guy did NOT follow protocol. He's supposed to stop me, tell me I was speeding, spend ten minutes chit-chatting about the car and then let me off with a warning. WTF...I think I'm more annoyed that he ignored the car than that he gave me the ticket. THIS MAN IS CLEARLY NOT QUALIFIED FOR THE JOB!
Old 06-29-2016, 12:37 PM
  #6447
Petza914
Petza914's Avatar
I hear you. Got stopped the other day with my son on the way to Cars & Coffee in the Spyder. Had just replaced the supercharger pulley andcl was doing a long full throttle pull watching the boost gauge forward any signs of slippage. Next thing I know there's a blue light special coming up behind me. He says he clocked me at 81 in a 55 on a state highway and I was still pulling, but decided that was fast enough so shut off the gun and started pursuit. He said "didn't you see me sitting upon the side of the road" so I proceeded to tell him about the pulley, boost gauge, etc. He wrote me at 64, which was nice, with the 81 in a circle next to it in case I decided I should go to court. Then asked what year the car was, said he'd never seen a convertible, and that it looked to be in great shape and to have a nice day, so although I got the ticket, it was reduced, and at least he noticed the car! Also wasca good opportunity to teach my young son how to handle a traffic stop properly -
>slowing down so they know you're not trying to run
>pulling off the road safely into a nearby parking lot rather than onto the shoulder of a busy road
>keeping your hands visible and not digging through the glovebox or reaching for the wallet until he's at the window so he doesn't get itchy
>being polite and courteous to the officer
>explaining anything that might have contributed to the situation to try and get some leniency
Old 06-30-2016, 12:10 PM
  #6448
Jehu Gearloose
Default Ground Strap
Took a break during lunch to replace engine ground strap. Not sure why it all-of-a-sudden seemed so urgent, other than I haven't had time in the garage for several days.
Old
New
There. Feel better now.
Old 07-01-2016, 09:57 AM
  #6449
Bucko74
Bucko74's Avatar
WOOHOO!!!!!!
Got the CPS out in one piece (and with no blood loss or profanities).
thought I was gonna be there for days..
Old 07-01-2016, 07:58 PM
  #6450
Pappy
Pappy's Avatar
Default Hall sensor replaced
Glad my AC is out! No air pump either. Was rather easier than I expected. Took the metal eye bracket out from underneath. That made it easy.
Did three shots of penetrate prior to starting. Made sure allen key was set and applied constant tight torque. Mine weren't bad.
Quick Reply: So what did you do to your 928 Today......
