Fixing a nuisance air bag system fault 3129/3229
For the last three years or so, I've been living with an air bag system problem on my car -- I get a red air bag fault warning every time I start the car, and the air bag idiot light stays on. Wally P. was nice enough to reset the fault for me at SITM a couple of years ago, but after a couple of months, the problem came back.
A few weeks ago, I got a JDS Porsche "spanner" and used it to readout the fault and reset the faults. Lasted only a few minutes this time. I'm getting "Lead Resistance High, Crash Sensor 1" (code 3129 or sometimes 3229).
So, today, I dug into things a little more, hoping I might just be able to try cleaning the contacts at the connector, etc. Just gettng to crash sensor #1 involves removing the RDK unit (which I'm leaving out this time, since I had it disconnected anyway), the mirror control unit, and the ABS control unit. The crash sensor is the black unit with the yellow blob of paint on it shown in the first photo below.
FSM on p. D68-9 "Test point 17" suggests (when getting a 3129/3229 fault) testing the crash sensor, which is supposed to have a resistance of 10 k-ohm between terminals 1 and 2 and 0 to 0.5 ohm between terminals 2 and 3. Also notable is that the FSM on p. 68-9 says, "The fixing point on the bodywork must be metallically bright."
I'd like to verify the resistance of the crash sensor (928.613.220.02, which is a $100+ part) before attempting to replace it.
So, here's where I could use some help from anyone more knowledgeable than I am:
I can't say I enjoy working under the dash. Today, with my back/shoulders on the driver's side footwell, legs placed on the floor outside the door, I hadn't noticed that my left leg's blood supply had been cut. When I got out of the car, I just about toppled over as my left leg gave out. Nasty. Probably a job that should be done by smaller people.
Edit: here's a photo showing the passenger (right) side crash sensor and the related connector.
- I'd like to check the resistance of the sensor, but I've tried disconnecting the sensor at the connector (it's shown in the second photo below), but I can't break it loose. Is there a trick to this? Is the connector locked in some way (I can't really see it, although I haven't really tried to get in there with a mirror yet; it's very cramped where the connector lives and it's behind the bracket it's fastened to. I don't want to break it by forcing it if there's some trick.
- Has anyone else ever successfully fixed this same kind of problem (i.e., a 3129/3229 fault)? What did the problem turn out to be?
Ed,
The PET diagram shows a long leads on the crash sensors (4), so you might find the connector under the center console or closer to the airbag controller (5).
borland
90' S4, Slate Metallic
borland
OK, I got the connector off. Turns out to be easy -- you just push both ends of the wires/connectors away from the mounting bracket and it pops right off. Apparently (based on what I can feel and the behavior), the connectors when plugged together are held in place (on the back of the bracket shown in the second photo in my original message) by a couple of clips, something like this:
Anyway, once I got the sensor disconnected, I tested it as instructed in the FSM and it checked out OK, i.e., 1..2 was about 10 k ohm and 2..3 was about 0.2 ohm. Connector appeared to be in perfect shape, too, and the pins appeared to be gold plated with no evidence of corrosion.
I guess I'll attack the air bag control unit next and see if there are any connectors there with bad connections (or at least give me a point to test the wiring between the sensor connector and the control unit).
I'd still be interested in anyone else's experiences troubleshooting this (or similar) air bag system faults.
Sterling, I might ultimately wind up doing the swap, but it's a real PITA, because these sensors are pretty hard to get to. The right side crash sensor is above the LH/EZK units, which must be removed along with their mounting plate. Probably a little easier to get to than the left side crash sensor.
The bigger issue, though, is that the sensors (and the air bag control unit) are attached with "tear-off nuts" (yup, that's really what they're called, painful as it might sound). The FSM calls for use of tool #9259 to remove them, and then they need to be replaced (they're single-use by design). I have neither the tool nor the replacement nuts. I could probably remove the tear-off nuts with a small hole saw or something, but I really don't want to do a hack job on this stuff; it's not a system that I want to screw up.
For now, I've put some DeoxIT on the sensor's connector and I'm going to button it all up again for this evening. I'll cross my fingers and rerun the diagnostics and see what happens.
If the problem remains, I'll make sure I get the right tools and perhaps a replacement sensor so I can do this right.
Shameful Thread Killer
Okay, I 've been in both sides of this system, and you are on the right track. I had the same fault codes indiciating fault in crash sensor 1. Once I removed and checked the resistance as you did, I put it back together and it worked fine. My problem was high resistance in the connector to the sensor. Those tear of nuts are a be-atch to get off with a vise grip.
Hopefully when you test again it'll be okay. The wiring from the sensors (4 diagram) to the controller go in on a large round connector on the back. The connector can be accessed by taking off the pass side trim panel covered by carpet and reach in with your right hand. It would'nt be a bad idea to unhook the conector and rehook it just to move things around.
I don't know if it's time to mention this but always work with the batt disconnected! The Spanner is a nice tool to ue to diagnose these problems. I think you'l find the fault was in one of the connectors you've moved around on the left side.
Doc
Doc
Thanks, docmirror. Your comments are encouraging. Kind of hard to believe that the connector would be a problem, as it looked like nice, clean, and tight-fitting, but we'll see.
I'm just about done putting everything back together. Much easier to do when you know how everything is fastened. I'll be up and testing within half an hour. I'm on beer break.
Yeah, I was very careful do disconnect the battery ground strap and give it awhile to discharge. I'm not taking any chances with the air bag system!
Well, air bag diagnostics passed, so we'll see how it goes over the next few days.
Time for another Paulaner Oktoberfest Märzen.
Mine's been working now for a few months. If you disconnect the batt again, or interrupt the power to the controller you may have to do another reset. Congrats, I think you got it!
Hey, you owe me a Paulaner, don't you?
Doc 90GT
Doc 90GT
Doc 90GT
BTW, Texas is the only place I've been where folks manage to make two syllables out of my first name.
For the record, it's been more than a week now, and the "air bag malfunction" problem hasn't reappeared, so I'm considering this issue to have been resolved.
Cleaning/DeoxIT-ing the crash sensor connector seems to have done the trick.
Well, it's been more than six years since I dealt with this problem on the left side, so I guess it was bound to happen:
(Sorry about the weird color effects on these instrument cluster photos; in the process of fixing some problems with the photos, I managed to introduce some weird color artifacts.)
When I saw that a week ago or so, I figured, "Well, it'll be the right side crash sensor connector this time."
Hooked up the DT999, and sure enough: "right front sensor line resistance too high":
Since my photos of the right side crash sensor and connector last time (see the last photo in post #1) showed things with the glove box removed, this time, I'll show some photos with what you're more likely to encounter if you don't have so much stuff removed.
(This is for a '90 S4; instructions probably vary a bit from MY to MY.)
Disconnect the ground strap and let the car sit for a half hour or so to make sure that there's no power supplied to the airbag system!
Remove the cover over the EZK and LH in the right side foot well.
Note: it may be possible to do this (and get to the crash sensor connector) without removing the EZK/LH/bracket assembly; I had already removed them before I noticed that it might not be necessary.
Then you remove the two cables from the EZK and LH. Remove the two socket-head screws holding the EZK/LH bracket (5 mm Allen head). Remove the bracket; you'll also need to unplug the relay at the bottom and the coding plug at the back before totally removing the bracket/EZK/LH so you can set it aside somewhere.
Remove the carpeted trim piece above where the EZK/LH was located; you'll need to unscrew three Phillips-head trim screws.
Now you can see the connector for the crash sensor (the barrel-shaped connector held in by a clip at each end to the right of the bulb control unit near the middle of the photo):
I unplugged the connector to the bulb control unit so I'd have a little more room to work. Then pry the crash sensor connector out of its retaining clips and disconnect the plug from the socket.
Inspect the contacts; they'll probably look nice and clean (they're almost certainly gold plated):
But... you should apply DeoxIT (I use the D100L solution) to the contacts and then plug/unplug them a few times, and finally reconnect and reinstall into the retaining clips.
Reassemble all the other stuff that you had apart.
Finally, fire up your favorite tool that allows you to reset the airbag fault (I used the DT999 again):
And... (if you weren't taking more photos like I did), you should be done within an hour.
After approximately 15 years (left side) and 9 years (right side), this problem hasn't returned.
That probably qualifies as a problem solved.
Bertrand Daoust (04-11-2020)
Basic Site Sponsor
Basic Site Sponsor
Yes, I'd call that "fixed".
Excellent job...great tip.
Almost everyone would have just bought a sensor.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
