928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 10-08-2011, 07:15 PM
  #1861
jorj7
jorj7's Avatar
Replaced the hood and hatch shocks on the GTS.
Old 10-09-2011, 12:11 PM
  #1862
NC928S4
NC928S4's Avatar
Checked vacuum line for transmission. Checked out ok. This completed LH, EZK, Idle/WOT, Idle Stabilizer, Temp II, Resonance Flap and Tank Vent Solenoid tests. Thankfully all tests passed and I learned a lot along the way without any bloodletting.
Took her for a spin. Idling, Running and Shifting well after multiple adjustments on Throttle body cables. Beautiful day in NC.
Old 10-09-2011, 12:20 PM
  #1863
rexpontius
rexpontius's Avatar
I did a whole bunch of work today, reassembling the 86.5:
- Finally fixed the sunroof with new seals, it now opens and closes the way (it think :-)) it should
- Mounted a new sunroof spoiler
- Put on the window trim on the windshield as well as the window of the trunk
- Fitted the S spoiler on the trunk
- Installed the 'headliner' of the trunk and doublechecked all wiring
- Installed the hatch lock
Next weekend is planned for the windows and trim of both doors.
The weekend after that, hopefully it is time for the front + rear bumpers and front wings, so it will look like a car again :-)
Old 10-09-2011, 12:42 PM
  #1864
davek9
davek9's Avatar
I pulled the engine out of the 86.5 Auto "onion", another layer exposed
Old 10-09-2011, 12:45 PM
  #1865
finally!
finally!'s Avatar
After removing rear wiper and motor didnt like the gaps, etc. left on the hatch or at bottom rear edge so cleaned them up!
Hatch trim piece with hump removed, cut some sheet metal and after much coerceing got it to a near exact fit. Attached with multiple tubes of JB Weld, sanded and smoothed out then covered with matching vinyl. On the carpeted pieced did the same thing and recovered with carpet left over from when installed all new carpet from Rob Budd...
IMHO looks MUCH better!
And on Friday sold the '08 Audi A4 so could reacquire the 1990 300ZX Twin Turbo I sold in 2007!
Old 10-09-2011, 02:58 PM
  #1866
Saskgman
Saskgman's Avatar
Changed vac lines, new spark plugs, wires, dist cap and rotor. Also did the delco swap on the 81.
Today changing out some of the bad fuel lines..
Old 10-09-2011, 08:29 PM
  #1867
ammonman
ammonman's Avatar
Replaced the vac line section from the manifold to the hard line on the top of the torque tube. Have noticed hard 3-4 shifts lately. Figured I broke it when I did the motor mounts. Also started the 2nd try on repairing a hole in the leather steering wheel cover. First try lasted about 3 months before the filler started cracking. Talked to Leatherique and got a couple of tips, namely glue the entire fabric backer for the hole down not just the edges.
Mike
Old 10-10-2011, 01:46 PM
  #1868
DanielD
DanielD's Avatar
Replaced the ABS pump. Flushed the brake lines with new fluid. Works like a champ...
Old 10-10-2011, 08:15 PM
  #1869
gmendoza
gmendoza's Avatar
Since the 928 is new to me, I decided to check and make sure the throttle position switch worked, cable adjusted properly, intake flap worked.
Turns out, the vacuum lines to the fuel pressure damper and intake flap were switched. All good now.
Old 10-10-2011, 08:20 PM
  #1870
MainePorsche
MainePorsche's Avatar
Voskian and MainePorsche representing the Tribe well at the Owl's Head Transportation Museum Classic Car and Antique Aircraft Show in Owl Head, Maine.
/Users/macbooktx/Desktop/owl head.JPG
Edit: Having trouble uploading photo.
Old 10-10-2011, 08:29 PM
  #1871
Ducman82
Ducman82's Avatar
Got and failed an emissions test. High HC count. Think I'm to lean.......
Old 10-10-2011, 08:38 PM
  #1872
voskian
voskian's Avatar
Had a great day, met MainePorsche and his son and great day for drive. Got 100 miles back down to home and belt tension lite went off 1 mile from home, guess running it to redline in third to pass the leaf pipers on RT1 stretched it a bit. Left it in Maine and will take tools back next weekend to adjust TB. It was replaced 4 years ago and 20k miles. Haven' t had it adjusted in last 4 years after it was installed.
Picture thanks to MainePorsche!
Old 10-10-2011, 09:05 PM
  #1873
the flyin' scotsman
the flyin' scotsman's Avatar
changed the engine and battery ground straps.....my car was built in late '87 so although its registered as a '88 it really is 24 YO
Old 10-10-2011, 11:05 PM
  #1874
SMTCapeCod
SMTCapeCod's Avatar
Intake R&R PLUS....Some of which I will still be buttoning up tomorrow.....
Pulled intake, stripped, prepped for paint tomorrow...admittedly a quick bandaid. Wasn't in plans but coating came off in sheefs despite careful handling.
Vac line kit.
4-hole cleaned Ford injectors
Porkens S300 Chips (regulator, etc)
All those rubber bits...
Fuel lines...o rings....etc,
Etc
I don't like making fuel lines.
I hate vacuum lines.
That is all.
Old 10-12-2011, 08:40 PM
  #1875
Tony
Tony's Avatar
Uhhhh...Got that lower right part of the fuel and ignition map pretty well sorted....
Quick Reply: So what did you do to your 928 Today......
