The Twin Screw Thread
#2431
I have a copy of the old Keel install manual if that helps.
As far as I know, there was only a "draft" version of the 928specialist manual, and it was for the last generation kits. I dont think there are any of those floating around out in the wild. If you did get a copy of that manual, I dont think it would be applicable to any earlier systems.
#2433
Its easy. The female portion of that connector is readily available. I do also have a source for a version of the male, but it does not have all the pins populated, so may not work for your application. Just lop off the factory connector and crimp on a 6-pin weatherpack connector, and then make a new JPT to Weatherpack harness in whatever length you want. Parts should be under $50.
#2434
Received 1,638 Likes
I 'have' the manual because I wrote it. It was 95% complete when activity ceased.
I don't think that there were anything but minor changes (and I think only one change) to the very few kits (and partial kits) that came after the manual. I'm happy to email missing pages to anyone with 'the kit.'
Can't opine on how appropriate the manual will be for folks that substitute parts or need to otherwise 'make' assemblies that would have been included in pre-assembled form in the production version.
#2438
In Your Face, Ace
Lots of requests for the manual in part or in total have appeared. Please stand by. I will get it done today if possible.
#2442
#2443
The dropbox app is such a pile of crap. The manual has been 'syncing' with '1 min left' for the last 19 hours. My upload speed is not THAT asynchronous.
If it ever finishes I will send the link.
Note that there are no missing pages. There is a page number 'issue' that makes it look like pages are missing.
#2444
The mostly-finished draft of the installation manual for the 928 Specialists Twin-Screw kit has been uploaded. I've sent PM's to all the folks that have requested it. In the past D.R. has asked me to make the manual available to folks that have his kit (or partial kits.)
I'm not going to make the link public unless D.R. says it's OK to do so.
In general, I'd appreciate it if the 'circulation' of the manual is keep to a minimum if for no other reason than that it IS an unfinished work.
Last, I am skeptical that the manual will be useful for folks that have a Keel kit. D.R.'s kit left virtually nothing the same.
#2445
