928 Forum 1978-1995
Sponsored by: 928 Specialists
The Twin Screw Thread
Old 10-08-2007, 02:30 PM
  #1621
Darien
Darien's Avatar
Here you go...
https://rennlist.com/forums/showthre...85#post4480585
It was Ken's idea, we just mad a few changes
Originally Posted by Tony
Darien you have the pics of how we routed your intake in the fender? I cant find them on my comouter?
Cameron, you need to do what Darien did.
Old 12-27-2007, 03:16 PM
  #1622
Ralph Newman
Ralph Newman's Avatar
I have been searching the site for a larger oil filler mod. I think a few people have done it ( maybe Louie). Any help?
Thanks and Happy Holidays
Old 12-27-2007, 04:18 PM
  #1623
pmotts
pmotts's Avatar
I am guessing you have the TS? We recently changed mine to the cam cover. I'll see if I can find a picture.
Jim
Old 12-27-2007, 04:58 PM
  #1624
Louie928
Louie928's Avatar
Hi Ralph,
I did use a different oil filler on Jim's car. I think it will work ok. It's from Summit racing. I cut off one of the cam cover breathers and welded this on.
https://rennlist.com/forums/attachme...1&d=1198789049
Old 01-23-2008, 10:21 AM
  #1625
Vlocity
Vlocity's Avatar
So:
I just got my LM- 1 today as an interim step to the eventual Sharktuning. I am looking for advice on where to install the bung for the 02 sensor. My first inclination is to put it in the other down pipe similar to the location of the existing 02 sensor. I am concerned though, that it would be monitoring more or less only one bank. (Doubtful there would be much reversion)
The next question.....what kind of number am I looking for at WOT. 11.8 - 12.0 ?
The set up I have used to this point is just and ARM guage and I have full BLUE lights under WOT and a good "hunt" at cruise.
Thanks for the help....
Ken
Old 01-23-2008, 10:27 AM
  #1626
AO
Supercharged
AO's Avatar
Originally Posted by Vlocity
So:
Ken
Ken-
If you put it on the other downpipe (Like most of us) it's true that you're only looking at 1/2 the engine (5-8 or 1-4), but remember that the each distributor handles 2 cylinders on each bank, so I think it's a non-issue.
As for a number... my goal is to be in the low 12's at WOT like 12.1 ~ 12.3.
Old 01-23-2008, 12:02 PM
  #1627
Tony
Tony's Avatar
Ive got an Xpipe with two bungs. Both are prior to the X and one either side. I made a heat sink out of some sheet copper and sandwiched it between the sensor and the Xpipe. Its about 4"x4" with a hole near the center. Its hangs down a little into the airstream. I am still on my original LM-1 wideband sensor for about 3 yrs now. I should probably buy a new one anyway as i plan on ST'ing soon.
Low 12'3
12-12.4 seems to be the consesnous from my reading.
Old 01-23-2008, 12:16 PM
  #1628
Darien
Darien's Avatar
Ken, You'll probably get alot of opinions, but I placed immediately down stream the X. I wanted to capture readings from both sides after they mixed
And don't forget not to install it on the bottom half of the pipe. It has the potential of getting wet while not running and could cause damage to the sensor.
Old 02-14-2008, 04:50 PM
  #1629
Darien
Darien's Avatar
Default Latest dyno
Looks like Ken's cold air intake and some AFR shark tuning gained me 34 RWHP
You'll see a little flutter toward the high RPM's and I think that's linked to my MAF being maxed out. I'll post my results after I install Tim's MAF donut.
The best run hit 465.60 RWHP and 436.55 RWTQ
The sheet shows the differnces before and after the latest improvements.
The vid link is of the 452.78 rwhp 399.44 rwtq run, I was too busy sitting in the back on my final run.
Enjoy!!
http://s151.photobucket.com/albums/s...560DynoRun.flv
z
Old 02-14-2008, 04:59 PM
  #1630
Rick Carter
Rick Carter's Avatar
Darien,
What size injectors and what fuel pressure? Congratulations! I'll be in Vegas 3/07-3/09.
Old 02-14-2008, 05:07 PM
  #1631
Darien
Darien's Avatar
Hey Rick,
I'm running 30Lb injectors with 70ish FP.
Make sure to look me up when you come to Vegas..maybe Tony will be in town also
Originally Posted by Rick Carter
Darien,
Old 02-14-2008, 05:21 PM
  #1632
Tony
Tony's Avatar
Ill have to check my sched but i should be around. Im supposed to head to the sim for the annual *** kicking in march. Its not posted on my sched yet though.
Just to help explain the runs..
BLUE run was with a new intake in the fender with a WAY bigger filter and a Sharktune
RED run was a small filter in the engine bay and stock chips.
nothing else changed. Both runs were in 3rd gear.
Old 02-15-2008, 12:29 PM
  #1633
Vlocity
Vlocity's Avatar
SWEEEEEEET !
So ....I just want to follow along here.....this is with fuel optimization with the Sharktuner, but NO ignition changes except the low octane loop plugged together correct?
You also have No knock sensor...correct?
That is just awesome. I see that some dynos will chart an "average HP", which I always thought was the strong suit of the Positive displacement units....do you have that number?
I'm still behind, but will get to the Sharktuning in another month.
Congratualations ! Looks like the filter idea may have helped a little.
Ken
Old 02-15-2008, 03:24 PM
  #1634
Darien
Darien's Avatar
Yes, correct, correct and yes
I'm sure I can get the average HP numbers from the guy, but this is the same type graph that I've always received.
Speaking of the new air intake/filter, it's freaking awesome A few things I noticed: You can actually hear the mass amount of air flow while under any boost load. When I installed it, I was running a S-tuned chip from before, and my AFR's leaned way out, which was a sign of gaining more air flow over the original tube and filter.
SWEEEEEEET !
Ken
Old 02-15-2008, 03:52 PM
  #1635
John Speake
John Speake's Avatar
Great result, Darien :-)
Do you have some pics of the new air intake/filter setup ?
Quick Reply: The Twin Screw Thread
