Project V8- VT951's Bitchin' Camaro
#184
that 924 is clean...get a new coolant tank though!
if anyone has an LS engine out of the car, could you give me a measurement of the engine from crank pulley to rear block face? width and height would be appreciated too.
#187
We haven't installed the f-body crank pulley yet (C5 pulley is still on there and it's quite a bit different "offset"). We can probably estimate what it will be with the f-body pulley if you want us to.
#190
Real World Dims
Truck crank pulley to factory fans/radiator is 1.125". This is with 1/2" between rear driver's side head and firewall. So the F-body pulley would leave 1.875" between it's edge and fans in their stock location. Hope this helps....
I know 100% that the Truck Crank pulley is set out 0.75" further than the F-body Crank pulley. But I have not had a Corvette Pulley or C5 alternator bracket to confirm the Dimension in the pic. I have seen another chart of these 3 diff. crank pulleys that are conflicting for the Corvette offset......reason why I haven't made Power Steering/Alternator accessory brackets for the Corvette Crank pulley offset....
#192
#194
Hood scoop. The intake would have not allowed the hood to close otherwise. I bought that hood scoop off eBay. The car is currently under the knife. I'll post pics later but you can check out the project here:
CRAZY PROJECT: http://www.924board.org/viewtopic.php?t=30684
