@Westcoast It was MHI2_US_POG11_P5186 1476 and I used AIO (ver. MHI2_US_POG11_K5186_1_MU1476_AIO_20220723). The PCM now shows MHI2_US_POG11_K5186 1476 for the firmware.
Then it could be that the SVM fix see's that essentially the firmware doesn't change so no fix is needed.
Got together with @718socal recently for some coding on my GTS. It turned out to be a great outing as several small changes have made my car even better.
We coded the lane-change turn signal flash to four flashes (instead of three)…programmed the Auto Start/Stop to retain its selected state (turned off, it stays off)…and the BIGGIE, added the factory Navigation module to my PCM. Activating NAV also enabled the GPS antenna which makes the altimeter, compass, and auto clock setting available.
The whole process was impressively fast and efficient, thanks to @718socal and his experience in making these changes.
My thanks to him for his time and expertise.
I'm really interested in this. Can it be done remotely?
MY24 may have PCM 4.1 (no Physical CD/DVD player) if so the MIB is not yet available for this hardware.
Mine has a CD player. I mean could I go to a dealership and get the Navigation turned on? It's it as simple as a credit card swipe and a tech tinkering with some software for half an hour lol
As it has the CD player it is likely a PCM 4.0 and you can enable OEM Nav yourself, or if you are feeling so flush pay the dealer to do it...
If you have the car, provide a screen shot of the hardware/software version if you want to have a go at it yourself so we can confirm that you are good to go. Also do you have Car Play activated?
@Westcoast I think the early MY 2024 cars have the older PCM 4. No way to confirm unless we look at the VIN and build date. I still can't believe Porsche released a new PCM for just one year. 🙃
It was built in late November of 2023, at least that's what TYD app said, then it sat* for four months lol. If I gave you the VIN you could tell?
Currently out of town but I'll get pictures when I get back and get all the relevant information
If you're asking about PIWIS coding for other things, yes. You'd need a low latency internet connection at the car, probably hardwired/ethernet direct to the windows laptop. PM 718Socal. If you're asking about the Nav retrofit, there's no coding (you download the AIO on a SD card and load it into the PCM).
