OEM Navigation Retrofit DIY
#601
Hey all - going to give this a whirl today to see if I can enable AA on my '22 Spyder. My car has factory Nav and Bose, but no Carplay. I am an android user and would really like to have AA enabled. I had SIMA enable AA on my Macan, but if I understand correctly, using a service such as his is no longer necessary....but perhaps I'm misunderstanding something.
Is this understanding correct?: I can download the file MHI2_US_POG11_K5186_1MU1476_AOI_20220723.7z, unzip it to the root directory of a FAT32 formatted SD card (mine is 32GB), insert that into the SD card slot in my car, allow it to work its magic and when it is complete, Android Auto will be enabled on my car? No need to get SIMA to remote in, no need to code anything with PIWIS....nothing other than the simple steps above? If that is true, it is incredible!
#602
#603
Holy moly! That is great! Thanks for the comfirmation - going to give it a go....will post any questions as they arise.
718socal (05-14-2023)
#604
Delete.....
#605
Thank you so much @718socal for all the work you and @CaneTLOTW have put into this - it is really great to have this resource and ability to access all the features in the PCM. As stated above, my install went very well, except the very last step. After the update completed, I was trying to access GEM mode by pressing the CAR and TUNER icons on the screen rather than the physical buttons. D'oh! Now I feel like a real dullard.....but, at least I know I'm not alone! Anyway, I have now removed the SD card form the slot and realize that in order to access GEM to run the SVC Fix I need to have the SD card in there.....can I simply reinsert it and access GEM? I am afraid that reinserting the SD card will auto start the whole process again. Maybe the better question is: do I need to run SVC Fix at all? I really don't know what it actually does - just that I was supposed to run it.....
#606
Good to hear, IIRC the autorun file gets renamed on the SD card so it shouldn't start again when inserted. The SVM corrects and error that can be posted due to the version change in the PCM, yes you should run this and the back-up routine from GEM
#607
Der Tgr (05-14-2023)
#608
I am very appreciative for all involved - didn't mean to omit anyone.....hopefully @Westcoast and all the other contributors didn't take offense as none was meant.
The following 3 users liked this post by Der Tgr:
#609
#610
The following 3 users liked this post by 718socal:
#611
Just finished doing the "P87" map update for 2022-23. Took 30 minutes during a drive. Thanks to all that make this easy for us.
The following 3 users liked this post by Fast-Eddie:
#612
Hey guys. This is an awesome thread! I went through the entire thread. Ton of thanks to great many contributors and @718socal in particular for initiating this super useful DIY.
I'm in the process of trying this. Mine is MY23 Spyder. First step is to figure out if I have the GPS antenna. I dread the idea of pulling out the PCM as I have difficulty getting the Center Console trim pieces out; they are extremely hard to pry out. Regardless, my first question is, is there a consistent way to trigger the GEM screen? When I press CAR + TUNER at the same time, nothing happens. I was able to get that screen just once; subsequently, I'm not able to get in GEM. For how long CAR + TUNER be kept pressed? I tried up to 10 seconds.
Thanks.
Thanks.
#613
Thanks.
Thanks.
That being said have you installed anything via the process here? The reason I ask, is what are you looking to do? It likely has the GPS antenna considering the build date, I would recommend the AIO process, easier and faster,
718socal (05-23-2023)
#614
Henry, the key is pressing them at the same time... it should only be a few seconds.
1. You need to hit the actual CAR and TUNER buttons below the PCM screen... not the screen icons.
2. I think you need to have the SD card inserted or PCM rebooting from SD card to access GEM. I don't think GEM is 'generally available' with out the SD card inserted.
@718socal Can you confirm or correct point 2 above... not sure of the requirements to access GEM.
#615
Two things come to mind:
2. You will need the SD card with MIB in the PCM to access anything other than the Production GEM options. So for checking the GPS antenna, the SD card must be in the PCM.
