718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
OEM Navigation Retrofit DIY
Old 05-01-2023 | 04:21 PM
  #556
Fast-Eddie's Avatar
Fast-Eddie
Another successful update here using the MIB AIO option: MHI2_US_POG11_K5186_1_MU1476_AIO_20220723. I now have CarPlay and AA enabled (already had Nav). Took about 30 minutes and followed @Westcoast advice to not touch anything, and then wait, and still don't touch anything.
Next step is to try the map updates via SD card. Which map of the 2 map update files should I use for North American Region (NAR)? Do I need to install both, or just the latest version? As the later version is smaller, I'm thinking I need both ???
1) P85_N60S5MIBH3_NAR_NT_Q1.21 (21.0GB dated 9/30/2021)
2) P87_N60S5MIBH3_NAR_NT_Q3.21_2022-23 (10.6GB dated 11/11/2022)
If I understand correctly, you unpack these archives to the root of an SD card, then use the software update function on PCM to do the map upgrade ???
Thanks in advance
The following 3 users liked this post by Fast-Eddie:
718socal (05-01-2023), GTSPYDER23 (05-01-2023), Z06jerry (05-03-2023)
Old 05-01-2023 | 04:22 PM
  #557
CaneTLOTW's Avatar
CaneTLOTW
P87 is latest version and you onl istall that.
Yes unpack archive to SD, metainfo2.txt has to be in SD root level.
The following 2 users liked this post by CaneTLOTW:
718socal (05-01-2023), Fast-Eddie (05-01-2023)
Old 05-01-2023 | 04:25 PM
  #558
Westcoast's Avatar
Westcoast
Thanks in advance
Whoot-hoo! Always love to hear good news!
Yes, you have the process right for the maps, and I see that @CaneTLOTW has already chimed in about the versions.
The following 2 users liked this post by Westcoast:
Old 05-03-2023 | 01:29 AM
  #559
Zebra1975's Avatar
Zebra1975
Originally Posted by Westcoast
Use the bolded file shown above.
There are two ways to do the upgrade, option 1 and Option 2, Option 1 is the best way to proceed.
It would be best to have a small charger on the battery when doing this, the ignition will be on and the engine off so the battery will be draining. The map update can be done the same way, or only in the case of the map database update, the engine can be running.
Your owner's manual will show where the battery charger should be hooked up.
Any other question, fire away.
I did it. Everything was updated successfully. All thx to the nice and most helpful people on this forum.
Only thing I noticed when looking at the software version is the phone driver shows 0.0.0.0 for the version, is this normal or did I miss something?
Old 05-03-2023 | 02:09 PM
  #560
Westcoast's Avatar
Westcoast
Where did you see the info about the phone driver, I went looking but didn't see that. Is it working?
Old 05-03-2023 | 03:03 PM
  #561
Zebra1975's Avatar
Zebra1975
Under version info
most things are working, though sometimes when people call me that are already in my address book it shows up as unknown caller. Not sure if that's related to this.
Old 05-03-2023 | 03:11 PM
  #562
718socal's Avatar
718socal
Under Version Information in the PCM
Mine shows 0.0.0 too. It was still showing that before I used MIB
Old 05-03-2023 | 03:36 PM
  #563
Westcoast's Avatar
Westcoast
Under version info
Oh, I thought you saw this in GEM! (answer below) Caller ID would be more a part of the phone-PCM connection and data transfer, it has never been good with Porsche...
All good here, or should I say me 3!
718socal (05-03-2023)
Old 05-03-2023 | 04:30 PM
  #564
Zebra1975's Avatar
Zebra1975
Ah ok. I didn't know if there was a version number before or not. That solves that. Thanks for your reply. Cheers
Old 05-04-2023 | 01:01 PM
  #565
Fast-Eddie's Avatar
Fast-Eddie
My "Phone driver version" is now 0.0.0, like others. However, it used to be 43.472.559. Things seem to be working OK, although I don't really use phone calls that much. Perhaps, the MIB update is missing some metadata somewhere for the version number ?
Also, my original PCM version was MHI2_US_POG11_P5177(1453). It now shows MHI2_US_POG11_K5186_1 (1476).
QUESTION: Is there any significance in the "P" versus "K" ??? i.e. P5177 versus K5186???
Before and after photos are below:
Original PCM Version (from factory)
Original Phone driver version (from factory)
Updated PCM Version (after MIB AIO)
Updated Phone driver version (after MIB AIO)
Old 05-04-2023 | 01:57 PM
  #566
Westcoast's Avatar
Westcoast
@Fast-Eddie Looking into the Phone Driver version and Software version... as you know the rest of us are running the same versions.
Old 05-04-2023 | 06:38 PM
  #567
CaneTLOTW's Avatar
CaneTLOTW
@Fast-Eddie
Have not noiticed this phone driver thing so far.
Could be some display issue, have not heard about any issues from any of the AIO users.
P = Production
K = Kunde (german for customer)
P FW are normally coming from stock/factory
K FW is installed for the customer (by dealer)
In reality we have access to P and K FW, quite mixed.
Train changed for you, as the AIO is based on the latest publically available FW version, which is newer than the FW you had from factory on your car.
718socal (05-04-2023), Fast-Eddie (05-05-2023)
Old 05-04-2023 | 11:57 PM
  #568
Zebra1975's Avatar
Zebra1975
Anyone know how to get rid of this template banner in Waze on the bottom right of the screen? It's a little annoying lol
Old 05-05-2023 | 02:21 AM
  #569
Westcoast's Avatar
Westcoast
Never seen that before, don't have it on any of my vehicles that run Waze...
***edit*** Just a thought, as Waze runs on your phone, what about deleting the app and re-installing it?
Old 05-05-2023 | 04:06 PM
  #570
Zebra1975's Avatar
Zebra1975
I was thinking that also. I will try re-installing it tonight and let you know. Cheers
