718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
PIWIS 3 Coding Retrofit and Feature Request
Old 10-18-2022, 12:19 PM
  #121
Westcoast
Westcoast's Avatar
Received 4,702 Likes on 2,736 Posts
Originally Posted by Z06jerry
@Westcoast RoadrunnerGTS did it with X431, See post #54 in this thread;
https://rennlist.com/forums/718-gts-...request-4.html
Yes, I recall that post but it doesn't give the corresponding PIWIS menu item for the changes.
In my case I would be interested in the rear DRL activation.
Old 10-18-2022, 01:25 PM
  #122
718socal
718socal's Avatar
Originally Posted by Richard Hamilton
Best bet is to do an OBD VAL from the Additional Menu, and output to PDF for a permanent record.
Can you see the other range 4-6 in your OBD VAL zip file?
Old 10-18-2022, 02:25 PM
  #123
Richard Hamilton
Richard Hamilton's Avatar
I can't say I have tried it on my 718, but they show on the many 9x1 cars I have connected to. I wasn't saying yours was the 'wrong way', only that an OBD VAL can be printed to PDF to give a permanent record, rather than a screenshot with little other info.
Old 10-18-2022, 03:18 PM
  #124
718socal
718socal's Avatar
Gotcha. I ran the OBD VAL and I could not find anything over range 3. @rnlst_log pointed me to this article
https://911virgin.com/engine-revs/Rev
Range data is stored in the cars ECU (engine control unit). The ECU is able to record and store engine ignitions at or past the car’s limiter. On a 6 cylinder engine, there are 3 ignition pulses per engine revolution. Ignitions are recorded as a cumulative total throughout a cars life.
  • 986 and 996 models have 2 Rev Ranges. Rev Range 1 records ignitions at the rev limiter whilst Rev Range 2 records ignitions beyond the limiter
  • 987, 997, 981 and 991 models have the ability to record ignitions in 6 different ranges. Rev Range 1 and 2 record ignitions at or just below the limiter. Ranges 3 through 6 represent increasingly higher engine speeds
Maybe on 982 the rev ranges are 1-3 set by the factory. Someone can try this on X431 or other OBD scanners and report their findings.
downshifted (04-23-2024)
Old 10-18-2022, 03:23 PM
  #125
Westcoast
Westcoast's Avatar
Do you guys remember how long it took the OBD VAL to run to completion?
Old 10-18-2022, 03:32 PM
  #126
718socal
718socal's Avatar
I just did it with the engine running in Dev mode 10-15 mn. The Serv VAL took about the same. I did it a few times and it got stuck once and I terminated the session
Old 10-18-2022, 03:48 PM
  #127
718socal
718socal's Avatar
Originally Posted by daaa nope
Ok so not quite a "coding" or "feature enablement" request but since all the PIWIS experts are already in here:
Can anybody tell me where the "overrev range counters" are? It was easy to find with my old Durametric but I haven't been able to find it in the PIWIS.
Also - a contribution to the thread - for those looking to see the oil level via PIWIS (as it wasn't completely straightforward to find):
It's under the DME -> Actual Values -> Oil Pressure -> Engine Oil Level Sensor and Engine Oil Level For Instrument Cluster
Just did an oil change on the Spyder this past weekend and used this to cheat on the oil levels (vs. starting the car and waiting for operating temperature.)
I found the values to run this in Dev Mode thanks to @rnlst_log
Choose DME => Actual Values =>
Eng Prt nr Ign N Max1
Eng Prt ti N Max1
Eng Prt nr Ign N Max2
Eng Prt ti N Max2
Eng Prt nr Ign N Max3
Eng Prt ti N Max3
burnergt4 (10-18-2022)
Old 10-18-2022, 04:25 PM
  #128
718socal
718socal's Avatar
Did it go to that screen?
Old 10-18-2022, 06:01 PM
  #129
Westcoast
Westcoast's Avatar
I never saw that screen at all? I suspect that I would choose option 1 for the most complete information?
Good to know that it can be run with engine on, still need to get a proper PS for these adventures!
718socal (10-18-2022)
Old 10-18-2022, 06:03 PM
  #130
burnergt4
burnergt4's Avatar
Only 3 ranges?
718 GT4/Spyder apparently only has 3 ranges. Everyone I've talked to that's looked up this data via PIWIS have all seen the same thing.
Edit:
THANK YOU! I had been going to "Measuring the oil level" in V40.4 and the values are…very weird, and "Oil measurement" in V38.9 just straight up didn't work on my unit (something along the lines of "feature unavailable"? I forget, to be honest).
The following 3 users liked this post by burnergt4:
718socal (10-18-2022), daaa nope (04-01-2023), downshifted (04-23-2024)
Old 10-18-2022, 06:39 PM
  #131
718socal
718socal's Avatar
Thank you for confirming. There is always something new to learn everyday 😁
Old 10-19-2022, 05:08 AM
  #132
rnlst_log
rnlst_log's Avatar
Every day when you play...you will find new "Mystery:" unfolding.
718socal (10-19-2022)
Old 10-19-2022, 07:09 AM
  #133
RajuPatel
RajuPatel's Avatar
pardon me for asking this.. but would the programming be common for Boxster/Spyder and GT4 as well... I have a 2020 ROW RHD GT4..
Old 10-27-2022, 12:35 PM
  #134
Richard Hamilton
Just to confirm that on my 718S there are 6 overspeed ranges:
Old 10-27-2022, 07:27 PM
  #135
nobbyv
nobbyv's Avatar
Hoping someone here might be able to shed some light: I somehow inadvertently disabled my backup camera w/ my Launch X431. I have a module called “Reversing Camera”, and under that a setting called “camera_on”. It currently has a value of 30kPH. I assume this should actually be 0, as in the backup camera comes on at speed min of 0. But Launch won’t let me change it at all. When I enter a new value and click “Wite Code”, it comes back “Write Failed”. Can anyone confirm in PIWIS that this seems like the correct setting to change?
Quick Reply: PIWIS 3 Coding Retrofit and Feature Request
