SOUL | 718 GT4/Spyder Exhaust Development
#661
Tire Temps after install of OAP? Has anyone checked tire temps before/after the installation? I installed the SOUL OAP a few weeks ago and I just purchased a pyrometer last week and i was shocked yesterday when my rear tires where 115 on the outside, 122 mid and 130 inside. I have the stock setup, so no mod to camber and/or toe. Is this normal for the inside temp to be 15 degrees hotter, especially with no camber mod? I was going to get camber/toe mod, but now, i have to rethink this, because adding more camber will increase tire temp on the inside. I saw in post either here or another about excessive heat coming from the new SOUL OAP solution?
Thoughts?
Thoughts?
You will always have a bit more temp on the inside (if your alignment is correct)......even with shielding, there will be a bigger chance of higher temp on the inside because of various factors.
If you are talking about 15 deg Fahrenheit that's nothing...go for the added camber, you will need it.
#662
What I really want is the GT3 startup sound with aftermarket exhaust. For some reason I love the sound of the "choking delay" on the startup and then blasts with volume. No one can replicate that. If you heard it in person, it blows your mind. YouTube doesn't do it justice
#664
The good thing is that shielding and/or ceramic coating can be added at any time.
#665
Heat is definitely an issue on these cars. I had two coils fail on my Cayman S due to heat. Had to install 911 cylinder head heat shields to stop this phenomenon. PAG saved a few nickels not putting them on the Caymans. That car had lesser horsepower than a GT4, and we are now up to 414-450 for these cars. Whatever OAP I eventually purchase, it will have the wrapped aluminized type of shielding on it. Anything to keep heat out of the engine compartment.
minn19 (01-20-2021)
#666
I also had the same problem...but you are talking about coils which are within a few inches from headers up front, right next to the engine (another heat source).
I agree, PAG decided to save some $$$ on those coil shields. I added them after changing all 6 coils. A must on the 981, specially if you track the car.
The area where the GPF resides is around +30 inches behind the headers in and area that has air flow....having the GPF does indeed create a cork that causes a heat build up but not after taking it out.
Extra safety is great and doesn't hurt but this is a non-issue once you take out the GPF.
Goodwood (02-20-2021)
#671
#672
Basic Sponsor
Thank you very much! Our guys take a lot of pride in their work and are quite passionate about it. If you scroll back to post #466 I believe, Mike posted a great article providing an inside look at some of our welding processes
Hey you say that, but we have another 718 GT4 showing up Monday to complete the Long Tube Street header development. Knowing you, I'll be getting a ring not too long afterwards to kick things up another notch haha. Either way, I'm super happy to see you've been enjoying the setup, and we appreciate the videos you've been sending us! : )
Thanks for the detailed feedback rooster. Give me a ring sometime, I'd love to ask you a few more in depth questions about your experience so far.
There's been a lot of fellows posting feedback on our race exhaust systems in the thread, and I'm sure you've read most of them at this point. That said, there are many running these systems that simply aren't active on Rennlist. I'll shoot you a PM and perhaps I can connect you with a couple to chat with directly for some more independent feedback. I want to make something as clear as I can, and I'll continue to say this to everyone inquiring about our Race Exhaust both in this thread and outside of Rennlist.
This is by no means a drone free exhaust system, it is a Race Exhaust specifically designed with priority in R&D for performance, weight loss, and overall pitch/tone at WOT in the mid range to top end of the powercurve. Cabin presence at cruising speeds was not a high priority in this particular system development, but it was considered and resonators were added as an option to take the edge off that drone and smoothen out the tone. It still drones, and everyone who drives it will experience that drone up until about 2800rpm where it clears up. The drone is much less on the 718 GT4 than the previous generations of 987/981, and to those people who have experienced aggressive race exhausts on the previous generations...or other cars...this could be considered more reasonable and perfectly manageable.
That said, drone sensitivity is extremely subjective and this may not be the system for you, but it could very well be. It doesn't matter how many people to talk to for feedback, it quite frankly doesn't mean a thing until you put it on the car and try it for yourself. If you want to try it, dedicate to it and place an order knowing that we are not the kind of company that leaves you hanging out to dry with a product that does meet your individual goals. If you don't like it, call me. We will come up with an alternative game plan, we've got your back with a no excuses no BS customer service policy.
Best Regards,
John Gaydos
I have a Spyder put my race exhaust about a week ago and love it, the drone is not a problem for me, I wish it was louder. I had a 981 GT4 which I had a race exhaust from another company which Matt drove multiple times at the SmokiesGT event the drone in that setup was insane and I put probably 30k miles on that setup. Thank you! John. I'm set!!
Had the resonated race exhaust installed yesterday and spent the better part of today driving. I love it. For me, it’s not too loud in the cabin and the drone hasn’t been an issue. Sure, it’s there. But it’s not terribly difficult to downshift a gear when you get into it. I don’t find myself in the drone range hardly at all anyway. The drone, again for me, isn’t as bad at neighborhood speeds. Highway with the top up it’s pretty bad on the meat of it. Great job Soul! All done rambling for now.
Anyone have any impressions of the Race Exhaust? Matt from OG really thought it was drony but I’m wondering if that’s just matter of gear selection when just driving normally. Is it truly that loud? If I’m going to spend more than half on OPF delete might as well get the Race exhaust and save 30lbs to boot!
Best Regards,
John Gaydos
SOUL PERFORMANCE PRODUCTS
Quality Exhaust Solutions, Fair Pricing, and Outstanding Service
John Gaydos- Owner, Performance Specialist
Cell - (484) 883-6197
johng@soulpp.com
Evan Litchko - Digital Marketing Specialist
elitch@soulpp.com
johng@soulpp.com
elitch@soulpp.com
#673
Basic Sponsor
#674
Agree with jmartpr's comments.
There are a few smaller vents to send air over the headers though, but not near enough to keep the engine bay from warming up. The concern for the shielding for the OAP is really to keep the tires and brake lines cooler. I don't want the inside of my rear tires to be 20-30 degrees hotter half way through a session on the track. Heat reduction can of course be achieved via insulated aluminized wraps or specialized ceramic coatings such as that done by Jet-Hot.
#675
Basic Sponsor
Yes it is truly that loud, especially with no cat headers. I’m sorry but volume is probably one of the least important metrics to getting to that perfect noise. IMHO it’s more about the pitch and undertones. The boxer motor has a host of subtle undertones and harmonics depending on RPM and a great exhaust let’s those through without causing your ears to bleed.
if you could take the noise the Soul race system makes and dial it down 20dB it would be perfect. Sadly, that’s a very allusive target.
It’s all relative. The PSE on my 981 BGTS was fine for me, never felt the need to spend any money on it. I’ll do the GPF delete with valve controller and see where I’m at. Contrary to popular belief the factory muffler design is actually pretty damn good so I’m not expecting to need to go beyond that.
Also, everyone needs to understand that a “race” exhaust, aka open pipes, behind the stock cats will be 2 to 3 times quieter than the same setup behind open headers. Remember, every 3dB doubles the volume.
I stand corrected and thanks for the link. The 3dB number was beat into me years ago but it was always a power discussion, not SPL or perceived.
The point I was making is still valid, it doesn’t take a lot, from a measurement standpoint to make a significant change in the perceived volume. I.e. LOUD does not always equal GOOD. I know Soul gets it as do many of the aftermarket exhaust makers else they wouldn’t spend the thousands of dollars and man hours they do trying to perfect the noise.
This may **** some people off and honestly I don’t really care, race exhausts are not appropriate for street vehicles, period, full stop. IMHO people who install these on street vehicles are the same people who think the quality of a car audio system is measured in SPL. There’s a reason people who race cars professionally all wear ear protection.
Now when it comes to our Race Exhaust on this platform with the stock headers...you'd have to hear it in person to really get a feel for it, but honest to goodness it's really not as loud as you would expect inside and/or outside for a "race exhaust". Our race exhaust for the 981 is WAY louder and drones WAY worse than what we offer for the 718 GT4/Spyder. I strictly steer people away from buying our race exhaust for any street use the 987/981 platform, I consider that a track only system. Considering how far apart in reasonable street driven experience these two generations of race exhausts are between 987/981 and 718...I can't help but stress that you can't simply say "race exhausts are not appropriate for street vehicles, period, full stop" as it just is not the case for this particular design race exhaust for this particular platform of car. For someone that can take some low rpm drone, it's something you can drive every day and fly under the radar on light throttle, with a wonderful smooth/high pitched tone at WOT that's not insanely aggressive...given you keep cats on the car! You really can't do that on our equivalent system on the previous generations cars. Of course this is a subjective opinion, but having driven more configurations of exhaust systems on these cars over the years than most anyone, I feel it is very accurate and transparent opinion despite it being a bit against the generalized assumptions of the "race exhaust" experience.
To note, I expect we're on the same page based on the above response that the Competition Headers/Race Exhaust is just ridiculous for most people haha. You had mentioned "if you could take the noise the Soul race system makes and dial it down 20dB it would be perfect. Sadly, that’s a very allusive target". I was hoping that's in reference to the combination with our competition headers, as 20db drop over just this particular race exhaust with factory headers would be a little boring haha. That said though, I would love to urge you to review the release of our "Sport Package" or our Competition Over Axle Pipes with our Valved Exhaust System in post #360. This setup combined with factory headers has all the benefits of the Race Exhaust's higher/smoother pitch but maintains a much more reasonable cabin presence at cruising speeds. It also comparatively reduces the overall sound level a notable amount due to implementing a secondary flow path even with the valves open. I feel like this setup is much closer to that dialed down allusive target that you (and we) were searching for as what I'd call the "Golden Ticket" setup for street use. Either way, I love constructive conversation like this and appreciate you posting it up
Best Regards,
John Gaydos
Factory Headers/Sport Package (Competition Over Axle Pipes/Valved Exhaust System)
https://soulpp.com/product/porsche-7...sport-package/
The following 3 users liked this post by Soul Performance:
