#8041
It's worth mentioning for those only recently exposed to the 944 model history that in later model cars including the S2 there is only one (singular) sensor and I honesty don't know if it's "speed", "reference" or somehow both. But there's only one.
I became very worried about my car when I discovered a single sensor. Not to worry. Your car is fine.
#8044
Installed my new 19mm adjustable rear sway bar, finally. It should be a good match for the 26.8mm front bar, the 18mm I had previously felt just a little too soft and I was getting some unwanted understeer in hard corners.
#8047
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/20170330_201451_6cba959626057abba3884896bb8b88ef8b66ee37.jpg)
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1124/20170330_201802_d7e3c399161535a5b3c28568cf2f3bdc88ac315f.jpg)
#8049
According to mahle it should be 0.62mm so I'll need to file some more ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Interesting part is they say ideal gap for 4" bore is 0.024-0.026'' or 0.006 per inch.
4.11"x0.006=0.02466" = 0.624mm
#8054
Installed new Alpine head unit into the 951 along with new rear 4x6 speakers. I was able to remove and install rear speakers without fully removing the rear side panels. I basically detached everything but where the panel goes up into the rear glass and just pushed up on the panel to gain access . It was very tight but I preferred this to taking out the rear windows to fully remove the side panels.
The original rear speakers were beyond destroyed. The new system is much nicer and the sound is more than adequate. I also like the ability for hands-free telephone calls now and the access to all music stored on my phone.
