Garmin Automated Coaching
#976
The bottom is used as the primary, until you put one in the side (for temporary use, like students or ride and drive). Then, the side one takes sole priority over the bottom one.
I cant recommend super large cards. As a matter of fact, I see more issues with supplemental and large cards on this device than most other issues on this device.
A bad sector in a super large one can cause video and data corruption. The 32 GB card included will record over seven hours. Buy the best quality you can afford. Class 10. Sandisk is good. A lot of counterfeit cards out there.
Generally, only the video is recorded to the card (the device treats the card(s) like external drives), as well as the rendered video with the data overlay that you can tell the device to render after the session. The data is in the tablet.
#977
Anyone using a screen protector they would recommend?
Also, the website indicates the primary memory slot(under removable lower panel) capacity is 256GB and the manual calls the side memory slot Auxiliary but I can't find how they are used together and what the auxiliary slot capacity is.
Can anyone explain how they work together? If using both which one can be used to transfer the data to a laptop?
#978
I see 3.9 has been released!
Wild Weasel (05-05-2021)
#979
Basic Site Sponsor
Basic Site Sponsor
Received 3,230 Likes
#980
#982
Received 1,695 Likes
Now now ladies, you're both very pretty....
#984
Basic Site Sponsor
Basic Site Sponsor
Sorry. Didn’t mean anything by my response. Snark’s reserved for only a tiny number of people, you’re not one of them. Edited the post.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Jmeide (08-22-2021)
#985
#986
So far so good with the Catalyst but for the love of god they need to improve their contact methods.
The contact support feature makes NO attempt to allow you to actually contact anyone. It places you where they think you should be.
Number is buried better than the Oak Island treasure!In case you need it !
1-888-442-7646
1-888-442-7646
ProCoach (05-07-2021)
#987
1-888-442-7646
1-888-442-7646
#988
1-888-442-7646
1-888-442-7646
#989
Basic Site Sponsor
Basic Site Sponsor
1-888-442-7646
1-888-442-7646
#990
Peter, are you seeing problems specifically with the Catalyst or is this just a general observation? I am using 256GB, which is the max size Garmin says they support, with no problems so far - although that be overkill, if Garmin say they support it, why not keep a more extensive set of data on the device?
