Isudar Carplay for PCM 3.1
#1711
Did you enable this feature on your PCM?
(10) No SOUND ? Pls activate original AUX on PCM3.1 - YouTube
What happens if you select CD instead of Tuner and then try to get sound via Carplay/Isudar? I cannot see how this can be possible. Can you play a CD and still get satnav audio from Carplay? If you can, then there is something going on with the Isudar board that I don't follow. If you can't then how can you get it from the Tuner input? As far as the PCM is concerned an input is an input.
Can you confirm that when you select CD you still get sound from satnav through Carplay, all at the same time? Also, if you connect some sort of audio device to the AUX input jack in your car and then play the FM radio, what happens when you select AUX. What should happen is that you hear the sound from the audio device connected to the AUX jack. It is really strange that this doesn't appear to be working this way.
None of this matters all that much really - the important thing is that you can listen to the PCM FM radio input and get audio from Carplay at the same time. I am just trying to get my head around how this is possible.
#1712
OK, now it is my turn to fall on the sword... I had it remembered incorrectly.
You can listen to a CD or other source including FM while having AA/CP running but you will not hear the audio from AA/CP, Google Maps and Waze will run but there will be no audio directions or alerts from them.
If you want audio from AA/CP (Isudar) then you have to select AUX as the source on the PCM.
#1713
That is how it works in my car also Westcoast. I was hoping there was a way to get audio from a CD and CarPlay at the same time but I don’t believe that’s possible. But it is nice at times to listen to a CD while the Waze maps are on the screen but you will not get Waze alerts
#1714
#1715
#1716
I have to admit that I did think this was the case.... Sometimes I don't need directions reading out, just seeing them on screen can be enough.
Thanks for the clarification. 👍
#1717
Meanwhile I've just ordered by Isudar board and now starts the long wait for delivery!
#1719
That's a very good point! On an unrelated topic, I have always used Google Maps for navigation but that only gives speed camera alerts when it's navigating to a location - not when you're just driving with maps on but not 'navigating'. Is this the same with Waze or does it give speed camera alerts all the time?
#1721
The main reason I use Waze is the alerts. I have tried pretty much all the satnav apps, and all have their different merits. But Waze is the one that, for me, comes closest to being all-round good. The camera alerts are timely and accurate. The mobile camera alerts come up as 'Police nearby', which could mean any sort of police presence, but often means a mobile camera. And the warnings for traffic jams, breakdowns, potholes etc are the best in the business by a long way, IME. I find the map display to be a bit 'cartoony' but it's a small price to pay for the rest of the goodies. I also like TomTom Go, but you have to pay for it. And HereWeGo and Sygic have their merits (but also paid apps). Waze seems to offer the best set of compromises.
Sorry for the Off Topic post. Maybe it isn't too far OT since a big motivator for getting CP/AA in the first place is to get a modern, up-to-date satnav in the car.
BTW, I always enable guidance even if I know the route well. Without guidance you don't get all the various alerts of problems on the route, and of course, you don't get detours around jams etc unless guidance is enabled.
#1722
PCM 3.1 isudar board issue
Hi all. Thanks for everyone who posted which has helped me in deciding to get the isudar board. I've all the post here and other threads to get mine installed. I am hoping someone may help me with my issues. Everything works on my install even with the xm board making it tight. My board is a v3 with the 230703v1 gr00 version. My issue is that my aftermarket backup camera would cause the pcm to not display the camera sometimes and basically resets the isudar board. I would have to select the 360 camera option in the backup advance menu before the backup camera would come back on. However sometimes the screen will just turn blank or black but the PCM radio would still be playing but can not be controller. I would have to pull the fuse of the PCM for everything to come back on and I would have to change the 360 camera option on and off for it to work but then after a while the cycle continues. Any help would be greatly appreciated. Thank you.
#1723
Issue: https://rennlist.com/forums/panamera...l#post18015038
Fix: https://rennlist.com/forums/panamera...l#post18265634
Diagram: https://rennlist.com/forums/panamera...l#post18283476
#1724
PCM3.1 carplay upgrade
Provide the best price of $259 in December.Use discount code "DEC100" to get a discount of $100Provides two-year warranty. link:Wireless CarPlay Android Auto for Porsche 911 Boxster Cayman Macan Cayenne Panamera
https://carlinklife.com/products/wir...deo-module-box
#1725
Hi all.
Well my board arrived today and like a big kid I jumped straight on it!
All went reasonably fine with the only two issues I had were:
1) one of the standoffs stripped the thread on the original motherboard - not really an issue as the other two are solid (plus I didn't have a tool to fit them easily so it was quite tricky as there's not a lot of space for one of them)
2) neither of the cables (not the ribbons) fitted particularly well onto the board - they're in but it wasn't a satisfying job getting them in there.
So now it's all in and working the only issue I have is that if I make a phone call I can't hear anything but the person I'm calling can hear me just fine (OEM microphone). Sound from Spotify and Waze, etc. is absolutely fine..... it's just the phone that I'm having a problem with.
Any thoughts?
One other question - do I need to use the supplied USB cable to carry out an update or will the OEM USB port work? Because I haven't fitted the supplied one!
Any thoughts?
