Received my new PIWIS III
#1411
I bought a set of these, cheaper buying 5 than 1...
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
siberian
siberian
#1413
Do you guys/Gals, also get a quick "spark" as you attach your Powermax power supply to the front battery posts....or battery ? I think this is "in rush" current to the power supply.....and not terribly bad. ??....but it bugs me. I have heard that some will introduce an old school light tester pen.....to slow down the inrush....and eliminate the "Spark" , remove it, then connect, thoughts ?
#1415
Hey @siberian
This is a smart thing to do.....mind sharing a pic of it mounted to your P/S ?
cheers !
cheers !
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/voltage_display_23b88e5f6bb2cf8664fe32b4e6582886937436c0.jpg)
Just used some fishing line and looped it between the cooling slats
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1105/voltage_display1_86a23ccdd4348daad2a983787b4fa55f2fb9667c.jpg)
Easily seen from within the car since it's facing the vehicle whilst the actual OEM gauge is on the opposite side facing the wall.
siberian
#1416
TBH I don't really know as the OEM digital readout can't be seen unless you stand above the unit. Also I'm not sure whether the OEM one reads the SET voltage vs the DRAWN voltage. My little add on just taps the supply ports thus the drawn one.
In these images the readout is showing set voltage of 13.8 (for LiFePO4 batteries) but as it's not connected to anything it's showing set voltage.
I must admit, I didn't think of looking at the OEM display when I took the pics, but I would assume since it's not connected to the vehicle it would show the same - set voltage of 13.6v.
siberian
siberian
#1418
In these images the readout is showing set voltage of 13.6 (for LiFePO4 batteries) but is not connected to anything thus not drawing any current; It's showing set voltage.
I must admit, I didn't think of looking at the OEM display when I took the pics, sorry.
siberian
siberian
#1419
Indeed, but when you're busy on PIWIS going through menus, you or I should say I tend to focus on the task at hand not icons on the top of the screen that are "informational" vs what I'm trying to do. This way, if I see the voltage start to drop on the instrument cluster, I can look up and see what is currently being drawn. Another MUST, is of course, turning off the DRLs, PCM, Fans etc. A good PowerMax 75 or 100A is a must have, cash well spent before bling add-ons. IMHO of course, YMMV ![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
siberian
PS Of course since you're just across the border give a buzz and come over, you can use mine.
siberian
Westcoast (04-21-2023)
#1420
Just wanna butt in here and note that I was having trouble with a newly fixed PCM and amp from Becker Auto Sound... @rnlst_log went above and beyond to help me troubleshoot and get things going, via the PIWIS and general wiring tracing. It was actually a super silly issue, but we got it all figured out. What a guy!!
Sajan (08-04-2023)
#1421
I wish there were Rennlist awards we could give to those who go above and beyond. I asked and, alas, there aren't. If there were, he'd definitely be at the top of all forums.
siberian
siberian
#1422
chassis (04-23-2023)
