Received my new PIWIS III
#1216
In case you didn't find it here it is:
https://rennlist.com/forums/992/1275...peedo-tip.html
siberian
siberian
#1218
Hi, i've Macan 2023 coming next week... it has not sport chrono package... but i want to add it.
Porsche dealer tell me they can't do at the moment...
So i was thinking that if i buy sport mode button, wheel frame (with hole where to fit the button bracket) and controller... then withi Piwis III i think it can be enabled.
Any experience (on model 2022 too)?
A question about interface.. what differences between VAS61554 and Piwis 3 clone interface? What i need for adding the sport chrono package?
#1221
@Marcus13190 , I've done the change you're looking to do on a 2020 Macan and a 2021 992 on both Launch and PIWIS so it must be there. Are you sure you checked in BCM2 in Engineering Mode?
siberian
siberian
#1222
Thank's for reply.
For turn signal is BCM 2 ?
Yes i've used engineer mode but i think that my VCI have had problem because on VX Manager the networt is offline.
I test it next monday because tomorow i'm in holidays
#1223
This is, as outlined in my post, to change the overtaking indicators from default 3 blinks to whatever number you want.
siberian
siberian
#1224
I just received my new tester and I figured I would share my thoughts since I have used both the 2 and the 3 now. I should be more precise as I did not purchase an actual PIWIS III, but remarkably they are for sale on sites like this PIWIS.NET On that site is the actual factory tool and currently sells for $5,900 which was way too rich for my blood. It is in the factory carrying case with all the cables and WLAN cap for the VCI that plugs into the usb mini port and allows for wireless connection to the car, along with the multimeter and oscilloscope cable. What I bought, which sells for around $2,000 and what is for sale in most places, is a Lenovo laptop with Windows 8.1 installed and the Porsche PIWIS III software installed and includes a USB wired VCI the same one the factory tester uses. I both cases the VCI and software have been modified to disable factory authentication and naturally there is no automatic updates. If you did have a PPN account, this tool would update normally. Most offer one year of updates and then charge for subsequent years. It should be known that the updates are really for adding new model years, not software changes. On to the review.
It is a nice laptop with a touch screen and a screen pen included. The Porsche software starts automatically, but the Microsoft button functions and you can do other things at the same time such as TeamViewer or open an internet page. The VCI ( the part that connects to the diagnostic port) is smaller and the cable connecting is shorter, but it is a standard USB to miniUSB cable so you can purchase an longer one anywhere. The tester can be changed from after sales mode to developer mode which allows for a lot of special features ( looking at you who want to disable start stop permanently). The software is faster, and easier to use than the previous version. For example on the diagnostic program, the tester auto detects the car model. Just plug it in, turn the key on and it does its thing. For me, I'm not sure if it is a function of the unit I have or not but the guided fault finding works well. Click on any fault and press the fault finding button and the unit tries to provide you a diagnostic plan. The plan is better and the English description is better. I haven't tried the wiring diagram software but I imagine it works as well as the previous version. There is a new ODBC program on the unit that reads standard ODBC codes, I am wondering if this unit can be used for other cars for simple code reading. I will try it on a buddy's car next week and let you know. There is a oscilloscope function and a multimeter function but the laptop clones don't come with these cables. If you check out the link I added you can see a factory tool and what that kit contains as compared to a laptop clone with VCI. All in all it is a better tool but really can't do more than the 2 can do, only faster and on cars from model year 2018 to current which the 2 can't do. Later I will clone the hard disk then see if I can upgrade the OS to Windows 10. I am certain it will work but cloning the SSD makes sense given my investment.
I recently bought a panamera 2 2013 flood in Copart you want help me to fix it? I can pay you for your help I live in florida and this can be like a weekend project for some weeks hahaha I hope you can help me I’m young guy loving this cars
#1225
Hi guys, I have a panmera 971, I would like to coded the matrix headlights 8JU/8IU PDLS ,8G4 LED , but I don't want to automatically coding all control units. Tell me which units should I coded? Bcm, Kombi, led left, led right and.... ?????
#1226
Originally Posted by porschemic
Hi guys, I have a panmera 971, I would like to coded the matrix, but I don't want to automatically coding all control units. Tell me which units should I coded? Bcm, Kombi, led left, led right and.... ?????
Coding the HL with the option is not enough. Been there, done that. My best guess is that at least some calibration of the HL is required on top of coding. There may be country restrictions that overrule the coding. I saw that when fiddling with ACC on my deceased 992
#1227
I'm from Europe, matrix is legal here
My friend was coding in hi Panmera and everything worked, but he clicked Automatic coding. I don't want automatic code because I coded manually bcm, bcm2, kombi.
#1228
Is the car originally for European market? Not imported from other region?
#1229
#1230
