Macan Coding
So reading the wiring diagram for a 2018 Macan (latest I have) and assuming the wiring code hasn't changed I tried to find a blue wire coming out of the backup/fog light housing. To my surprise (and that wasn't the only one today) I didn't see any blue wires but 4 black wires and one brown. Knowing that brown is ground, I now have 4 wires to decide which one is the reverse light. So I ask my friend who's shop I'm using if he can just start the car, put it in reverse whilst stepping on the brakes to make sure the car doesn't move. To which he replied, I'm not sure why you spent all that money on this analyzer... OF COURSE
! Connect it up and presto the Mini Pro activates the backup lights! SWEEEEEEEEET! But no voltage on any of the wires.
Now for the challenging news, whatever could be done easily has obviously been discarded by Porsche as being too plebeian. So instead of just running 12v to the lights or LEDs, in this case, they run some sort of PCM (Pulse Code Modulation) circuit so I'll have to find another way to determine when the LED is activated and steal 12v from that. More reading needed... but the Launch Pro Mini was a GREAT help!
As to the access panel for the oil drain, to my horror, what I assumed was a (even a thin) metal pan, is plastic
. Useless for anything more than keeping some dust off but definitely not a skid plate in even the remotest of terms. If it's to save weight why bother.A lot going on at home now so it might be a few days or week before I get back into this. But very happy with the 431x so far.
siberian
The best long distance runners eat raw meat, run naked and sleep in the snow
Mark, it did say it does battery registration which was one of the key items on my list even though I won't be needing it hopefully for 5 years. But I didn't want to spend this much cash and not have it do something elemental. I have a small window of time tomorrow so I'll see if I can start on some of the changes. I'll update my build page.
Thanx again
siberian
The bottom panels are there for aero and fuel economy.
Thanx Todd!
siberian
Hope the pups are all better. Ours is almost 15 and getting slow.
siberian
siberian
siberian
