Macan Coding
#121
Start/Stop is fairly easy.
The coding needs to be done in 4 ECUs (if I recall correctly Tiptronic, Aircon, PCM, and Power control).
the quick and easy way:
just select ALL ECUs in Piwis and de-select the ones which are definitely irrelevant (such as doors, DME, hatch, ..). Then you‘re sure you code them all together (process will be automated, sequentially ECU by ECU as you will see).
once selection has been done, select „Coding“ and scroll down to the Start/Stop option. It can be set to on, off, or Last Mode.
select Last Mode and press F12.
the option will be coded and the switch remembers its last setting. Done.
if you‘re uncertain which modules to code - just select all of them and de-select the DME (as DME does not get coded), then code them all.
just takes some seconds more because all ECUs will be read out, even though only 4 of them will be altered...
have fun!
have fun!
Any idea in the switch off speed for the parkassist/Surroundview? I changed it in park assist but still I can not manually switch it on above 10mph
#122
I did not pay any attention to the performance gauge, it did not work properly anyway.
Parkassist/Surroundview - never looked into it as I did not have Surround View. I was more than happy to have retrofitted the backup cam properly
#124
Yes, please scan through the Cayenne coding thread:
https://rennlist.com/forums/cayenne-...ussion-53.html
It's buried somewhere in there.
siberian
siberian
#125
Is it possible to code comfort entry into a 8 way seat with memory? Since the steering wheel is not powered it just looking for the seat to move back a few inches. Did not see this being referenced in the Cayenne thread. This is for a 2021 GTS
#128
Yep I have option Q2J, 14 way and then it is accessible. If it makes you feel better, I do have it programmed but find it retracts way to far back so when you're in again you need scoot forward to reach the pedal to turn the key. I think if they just moved the steering wheel way out of the way it would have made for a better deal.
siberian
siberian
#129
Hey was wondering if I could ask a few questions about PDLS to PDLS+. I have piwis 3, and all the right hardware in the Macan, but can't seem to find where in the software to enable it. Thanks.
EDIT: sorry I replied to the wrong user
#130
Interesting inputs.
Just to share quickly which mods I was able to code on my MY17 Macan, using Piwis:
- lowered air suspension by 32mm
- retrofitted a heated steering wheel
- retrofitted a OEM backup camera (PDC was in car, but w/o cam)
- Upgrade from PDLS to PDLS+ (since front camera and lights are the same) just by coding
- Memo function for the Start/Stop function (set to „last mode“) - this was the most annoying „feature“ ..
- Option of 22“ wheels (in TPMS menu)
- Option to automatically fold in rearview mirrors when locking the car. Unfolds when starting the car.
- some additional menus in the dash cluster, e.g. Power / Torque
- eliminate seat belt warning (just for testing) in dash cluster
#131
You have to change option 8EF or 8JE into option 8G2 (high beam assistant) in 3 ECUs:
- Front Cam
- Front Light
- BCM Front
this gives you auto high beam.
change the fog lights to option 8GH, this enables intersection light.
thats it- all can be found under „coding“ for the respective ECU.
I don‘t know the UI of Piwis3, so I cannot comment on that part, but it should work similar to Piwis2.
- Front Cam
- Front Light
- BCM Front
JUN6817 (05-30-2023)
#133
I'm trying to justify purchasing a Launch.
Anyone with ventilated seats - the car currently nannies me and tells me I'm not allowed to turn them on when the auto climate control is heating the air inside the car. Sometimes I want to heat my frontside but cool my backside! Is this codeable?
#135
Great to see it worked for you as well
It's live, please please help out and subscribe to my channel and share to your friends and family:
https://youtu.be/nyL-GwMkLq0
don16 (01-13-2021)
