Macan 2014-Current
Sponsored by: HBI Auto
Macan Coding
Old May 18, 2021 | 09:47 PM
  #151
runbuh's Avatar
runbuh
Originally Posted by Cheng Min
"Option to automatically fold in rearview mirrors when locking the car. Unfolds when starting the car."
Hello, How to coding for this? thnaks
The settings are documented in this spreadsheet:
https://docs.google.com/spreadsheets...it?usp=sharing
Old May 18, 2021 | 10:20 PM
  #152
dollarlongnecks's Avatar
dollarlongnecks
Wow, you guys are organized! That's awesome!
Old May 20, 2021 | 03:10 PM
  #153
ddaudi's Avatar
ddaudi
Line 71 of the spreadsheet is about the USA seat belt warning chime. in Column C it says "deactivated".
Is it possible to turn off the seat belt warning chime?
Old May 20, 2021 | 08:12 PM
  #154
runbuh's Avatar
runbuh
Short answer: Yes
Longer answer that sounds snarky but isn't meant to be: Refer to Column E for a description of each setting: "Disable seatbelt warning Chime"
Old May 30, 2021 | 05:02 PM
  #155
sebastianPT's Avatar
sebastianPT
6th Gear
If I read your spreadsheet correctly, a person with a 2020 Macan could activate PDLS+ with a Launch 431? Any clarification would be greatly appreciated. Thanks!
Old May 30, 2021 | 06:42 PM
  #156
M3Inline6's Avatar
M3Inline6
This is great information.
Old May 31, 2021 | 10:52 AM
  #157
runbuh's Avatar
runbuh
If you have the windshield camera, then you can enable HBA. If you have the Macan NAV, then you can enable Intersection Lighting. If you don't have the required hardware, then making those coding changes will not help.
Look here at the section that sierra055 started:
https://www.macanforum.com/threads/p...8#post-2638038
Also - the spreadsheet is not mine, it was started by @sterod , and many of us have had a hand in maintaining it. Just wanted to give credit where credit was due.
Old Jun 1, 2021 | 02:01 AM
  #158
Cheng Min's Avatar
Cheng Min
2nd Gear
thanks, it works.
Old Jun 3, 2021 | 01:39 AM
  #159
sebastianPT
6th Gear
Awesome--thank you to you, @sterod , and everyone else that contributed! Along that line, might you or anyone else know how to activate Lane Keep Assist (LKA) via an X431? I already have Lane Departure Warning (LDA), Lane Change Assist (LCA), Nav, etc., and know @don16 did it with a PIWIS III, but not sure what modules are involved in order to code it with an X431. Thanks again!
Old Jun 3, 2021 | 02:57 AM
  #160
FerdinandAG's Avatar
FerdinandAG
I think you will need Piwis
Old Jun 12, 2021 | 05:34 PM
  #161
runbuh's Avatar
runbuh
If you can see where Don16 did it, then you just have to translate that to the Launch. The modules/codings are the same, but you may have to translate German (PIWIS) to something-like-English-and-German (x431). Did Don16 publish a video of how to do it?
Old Apr 13, 2022 | 10:07 AM
  #162
kapetajr's Avatar
kapetajr
For anyone interested in getting the coolant gauge to read real time coolant temps, see here https://rennlist.com/forums/991/1283...t-the-fix.html
I made the same changes to my 2015 Macan Turbo a few days ago.
Pic below shows: left side Temps the gauge will show, right side actual coolant Temps.
To correct this I copied the X2 - X8 values over to the corresponding Y2 - Y8 fields
And adaptive brake lights. Brakes flash if the car sense a deceleration rate of -81.gs to .71 gs deceleration.
*Brakes Lights are currently set to flash for 2 seconds but that will be reduced to 1 sec.
Old May 17, 2022 | 04:06 PM
  #163
jonUF02's Avatar
jonUF02
This thread needs a top index of features like the Cayenne one.
Is it possible to enable Sport Plus on Macan with my X431? Then use the "joker" button to activate mode as described.
Old May 17, 2022 | 04:07 PM
  #164
sterod's Avatar
sterod
Enable as in if the vehicle does not already have sport Plus, no, that is an online activation code that must be purchased through Porsche.
​​​​​​If the vehicle already has Sports plus then yes you can use the x431 to configure the diamond button to activate it
Old May 17, 2022 | 04:49 PM
  #165
jonUF02's Avatar
jonUF02
Too bad the Russian site for activation codes is now unavailable
