Sponsored by: APR
Best Track Times in a GT4
Old 06-07-2021, 10:01 PM
  #1636
afilsinger
afilsinger's Avatar
981 GT4 Clubsport (Michelin Slicks), Buttonwillow 1CW. 1:55.31. This was my first time a GT4CS, seems like an awesome car. I think I can knock another second or two off this with seat time and minor setup tweaks. Video:
ProCoach (10-24-2021)
Old 06-08-2021, 07:57 AM
  #1637
jmartpr
jmartpr's Avatar
Received 1,483 Likes on 922 Posts
Originally Posted by IMZSTIG
718 GT4CS competition version. I’m new to the car, but here what I’ve got so far...
WSIR - (Yokohama slicks) 1:27.29
Streets of Willow - (Hankook slicks) 1:19.12
Chuckwalla CCW - (Hankook slicks) 1:50.82
Of those two slicks, which one did you like better?
Old 06-08-2021, 09:56 AM
  #1638
IMZSTIG
IMZSTIG's Avatar
the Yokohama are much better
Old 06-25-2021, 11:45 AM
  #1639
ShakeNBake
ShakeNBake's Avatar
Crossing another track off my bucket list. Made the trip up from Austin to Road America. We watched the indy race on Sunday at turn 5 and then had two blissful days on the track with Nord Stern PCA. Kyle Busch was there with us, practicing for the coming nascar race. Super interesting to watch his antics.
I started on Cup 2s and within a couple sessions was feeling pretty good, got down to a 32. Second day the Hoosiers came out and I was able to shave another 5 seconds off of that to a 27.5. There is easily another couple seconds to piece together from all my best attacks on each corner, and a likely many more with some coaching from someone who knows the track well. My second day was cut short with a low-coolant-error that put the car into limp mode.
981 GT4 w/track alignment, DS1.11 Pads w/SRF Fluid, 265/295 Hoosiers, BBi Wing extender on minimum attack angle.
Not claiming this is a best time or anything, but lots of onscreen data for folks who are about to learn the track. I wish I had this to learn before I got there.
The following 6 users liked this post by ShakeNBake:
jwr9152 (06-25-2021), Montaver (06-27-2021), phefner (06-26-2021), porscheflat6 (06-25-2021), Snowy999 (08-23-2021), xller8 (09-06-2021) and 1 others liked this post. (Show less...)
Old 06-26-2021, 10:22 PM
  #1640
acc_123
acc_123's Avatar
No Mosport times?
Old 06-26-2021, 11:03 PM
  #1641
rbpeirce
rbpeirce's Avatar
Sean Reiche, driving my car at Pitt Race, did a 1:57.67. The tires were overinflated to reduce edge wear which slowed him down a bit.
2021 GT4 with PDK transmission. Apex Pro shows this as a 2020 718 GT4 unless manually edited.
Tires were Dunlop Race 2 at 35/36 hot, instead of my more normal 32/33.
Front camber was -2.5°. Rear was -2.0°.
Toe was close to 0 in front and 13' per side in the rear.
I have adjustable rear toe links to get enough toe at that camber. Everything else is tock.
Old 06-26-2021, 11:42 PM
  #1642
phefner
phefner's Avatar
@ShakeNBake Thats an epic time at Road America for a street GT4, 2:32 on Cup2s and 2:28 with an R-Compound are right up there with some of the best I’ve seen yet. Well done. You guys had some great weather. Dodging storms the last few days at Road America with Northwoods Shelby this weekend.
How aggressive is your track tune?
Old 06-27-2021, 12:26 AM
  #1643
ShakeNBake
ShakeNBake's Avatar
We did have epic weather, high 70s and a smidgen of rain on Monday! I could not ask for a better day. Well, I did get black flagged very first session for passing to close to the kink, and then proceeded to miss the black flag - that could have gone better.
Alignment is -3.3F/-2.8R, 2mm toe in rear, 1mm toe out front, 10 degrees of caster. Using the tarret camber plates to get the caster up with that much camber, which seems to be key on this car. I don't recall the ride height exactly, but it's about 0.5" lower (maybe more) than stock, and we've messed with the rake to dial out some understeer, I think it's about +5mm from stock (rear higher relative to front).
Have fun!
The following 2 users liked this post by ShakeNBake:
phefner (06-27-2021), xller8 (09-06-2021)
Old 07-06-2021, 01:42 PM
  #1644
porscheflat6
porscheflat6's Avatar
Originally Posted by jreifler
NCM: 2:18
Throttle body, plenum, BMC filters, tune, Cargraphics headers.
Hoosier R7s on Forgeline 19s.
Tarrett LCAs, links, track alignment.
Last session before the Hoosiers corded and my student turned me into a rag doll . . .
https://www.youtube.com/watch?v=MgdpF0SYP5A
Nice driving!
Old 07-06-2021, 06:16 PM
  #1645
Errsomeone
Errsomeone's Avatar
Nice job on PittRace and remarkably similar to my time. Only been once but enjoyed it even if can be a little tricky to instruct and plan to go back again. Manual 981 GT4 on RE71s with streetable alignment yielded my time at 157.60.
Trying different lines and approaches with data helped as the track does allow you to overdrive, but trick seems to be patience is rewarded.
Old 07-06-2021, 10:57 PM
  #1646
rbpeirce
rbpeirce's Avatar
I don't know what it is worth but he had about 190# of ballast in the car, me!
Old 07-07-2021, 08:53 AM
  #1647
38D
38D's Avatar
rule of thumb: every 100# is worth up to 0.5 seconds per minute of lap time. Does depend a on the car/horsepower/aero/etc. So in this case, it’s would certainly be +1 second and up to ~2 seconds.
Old 07-07-2021, 07:28 PM
  #1648
rbpeirce
rbpeirce's Avatar
Let's do the math. 190# would be 0.95 sec/min and the lap was 1.928 min, so 1.83 sec or 1:55.84. My personal riule-of-thumb is I'm about 5% slower than the best non-professional drivers on this track. My best lap that day was 2:01.78, which is 5.1% slower. Close enough for government work!
Rule-of-thumb. I'm about 10% slower on tracks where I don't have the level of experience I do at Pitt Race. I'm about 15% slower than a professional driver [not Lewis or Max!] Conclusion: I'm pretty slow but I have fun!!
Old 07-07-2021, 07:47 PM
  #1649
9eight7
9eight7's Avatar
...Rule-of-thumb... I have fun!!
I can't wait to see how I compare here.
Old 07-08-2021, 09:52 PM
  #1650
ExMB
ExMB's Avatar
Received 1,378 Likes on 837 Posts
Going to 32As would save about 20 lbs or .1 sec. Correct?
Quick Reply: Best Track Times in a GT4
