E/SIM Racing For discussion and info on iRacing, SIMs etc.
Rennlist iRacing thread
Old Mar 10, 2014 | 10:29 AM
  #3781
HoBoJoe's Avatar
HoBoJoe
Originally Posted by PorscheZen
Would something like this work? - http://www.newegg.com/Product/Produc...82E16814125443
As it's significantly cheaper - $189 what am I losing or how would it compare to the two mentioned above?
I believe the GTX680 was the first Nvidia card that supports 3 monitors on 1 card. The GTX 770 is your best bet for an Nvidia card.
Old Mar 10, 2014 | 10:43 AM
  #3782
PorscheZen's Avatar
PorscheZen
Any opinions/recommendations on the AMD/ATI cards?
I have this unsubstantiated idea that nVidia cards produce betting quality imaging and is better for graphics needs in iRacing. True?
Sent from NSA HQ using Rennlist Forums
Old Mar 10, 2014 | 10:54 AM
  #3783
pmason's Avatar
pmason
Well I bought a XFX ATI Radeon HD 7870 2GB Double D in Dec. have everything turned up to it's highest settings with no problems. I can't comment on the different between nVidia as I never had one of their cards.
Old Mar 10, 2014 | 01:03 PM
  #3784
PorscheZen's Avatar
PorscheZen
Cool. That's helpful actually. Started looking around for one of these and not too bad on eBay. How many Watts are you running in your PSU?
Old Mar 10, 2014 | 01:19 PM
  #3785
User 52121's Avatar
User 52121
ATI vs. nVidia... honestly, you'll have the supernerds argue over which is better but at the end of the day, they're pretty much the same as far as performance goes. One might draw one type of image 1% faster than the other, or 1% clearer than the other, but then draw a different type of image 1% slower... but ultimately you've gotta be hyper-sensitive and basically know what you're looking for.
I don't think you can go wrong with either. I've had both, and have switched between both. Usually when I switch it's because one is priced better as a reasonable upgrade to an existing card. I went from an ATi 4870 to a nVidia GTX260, to an ATi 6970, and now to a nVidia GTX770. Just because I wanted to upgrade and the next upgrade was cheaper to switch.
Having just gone from an ATI to an nVidia card, both of which were driving triple screens, I'll say that, once you have the proper adapters, I think getting the ATi card set up was easier to work with triples. There's more info out there (especially on iRacing) doing triples with ATi and overall I think their interface/software (Catalyst Control Center) is more intuitive. Downside to ATi cards is that you need a bunch of special "active" adapters if you're not using a DisplayPort for your monitor connections.
Old Mar 10, 2014 | 02:16 PM
  #3786
North Coast Cab's Avatar
North Coast Cab
I just built my system and used the GTX770 4GB. Everything works great, but I'm not sure what you guys mean when you say "turned-up."
Old Mar 10, 2014 | 02:17 PM
  #3787
ny991's Avatar
ny991
My new rig has the nVidia GTX760 and I am totally satisfied. It's a 3 screen set-up with 3 ASUS 24" units, and everything aligns well, displays well, with no operational problems at all. The graphics are fantastic.
Old Mar 10, 2014 | 02:35 PM
  #3788
User 52121's Avatar
User 52121
Sounds like the track was fast last night. Sorry I missed it. We had a high of 41 degrees (OMG!!!) so a few PCA'ers decided that was cause to celebrate with 2014's inaugural BBQ.
Wife works Tues night so I'll probably host up a practice then to make up for it. I think I found a good rhythm on Friday night but would like to get some practice in traffic.
Old Mar 10, 2014 | 02:42 PM
  #3789
Jenner's Avatar
Jenner
There are ways to increase the graphics quality to it's highest potential on your video card control panel, in the iRacing control panel and in deeper/hidden settings.
This guide uses nVidia Inspector to enable features above and beyond what is available in the NVidia control panel. (I would assume a similar tool exists for ATI/AMD):
http://members.iracing.com/jforum/po...t/3192704.page
Advanced tweaking of AA:
http://members.iracing.com/jforum/po...t/3192536.page
Old Mar 10, 2014 | 03:09 PM
  #3790
pmason's Avatar
pmason
I only needed one Display Port "active" adapter, the other two monitors are directly hooked up to the DVI ports.
Old Mar 10, 2014 | 07:04 PM
  #3791
User 52121's Avatar
User 52121
Yeah it's not a huge pain, once you get the right adapter that actually works. Some people find it to be a bigger nuisance. The nVidia cards don't need any special "active" adapters by comparison.
Old Mar 10, 2014 | 08:23 PM
  #3792
PorscheZen's Avatar
PorscheZen
Learning lots here (insert popcorn munching emoticon)
Old Mar 10, 2014 | 11:03 PM
  #3793
Gator_86_951's Avatar
Gator_86_951
Spell Checker
I just need the space to do the three monitors. Unfortunately, that isn't in the cards until at least the August time frame. I don't think the 46 TV output is really slowing me down that much, but I think I would get some benefit out of the three monitors for sure.
Old Mar 11, 2014 | 12:54 AM
  #3794
PorscheZen's Avatar
PorscheZen
Jack, Do you have the 2GB or 4GB version?
Old Mar 11, 2014 | 09:46 AM
  #3795
tasracer's Avatar
tasracer
Home!
What track and I need practice!
Sent from my iPad using Rennlist
