Rennlist iRacing thread
Did you get the links I sent earlier today? You start the Sim Commander, it should detect that you have iRacing and show you a large icon of iRacing in the middle. You double click that to get into iRacing so it uses SimVibe. But to configure it on the bottom of that screen there is a button on the right that gets you to the configuration part. You select the second tab on top I think, and then get to the sim device manager, see the tuning guide. There is where you set which mode you want to use, and you can also test it from there.
The thing I didn't get right away was the double clicking the iRacing icon, it opens it's own browser to start the iRacing interface.
I think you have to configure which mode you want to run first and assign which sound source you are using. Then when you get to the mixer and if there isn't anything there you can hit that add button and then you select the effect you want for that slider.
On the top there is another tab for the configuration.
Ok
It's working!!
But I can't drive a fast lap cause I'm laughing my *** off
Holy ****. Sooooo cool
But I can't find the tire slide effect
Is that only in extended mode and not chassis
I'm running chassis mode with rear only hooked up
Sent from my iPad using Rennlist
It's working!!
Congrads, I did the same thing when I first got it working.
Yea I haven't found that effect either, but haven't looked under the extended mode but I do recall not every effect is available for all the different sims it supports. You will want to tune it, just alt tab to go between the mixer and iRacing to see how the change is reflected in the sim.
