Rennlist iRacing thread
#3706
Yes. When ran earlier this year someone setup a practice at night and it was extremely the opposite how it was during the day practice. Problem is, I can't recall which was which.
#3711
There is always that slight chance. Going to Sebring for the 12H... friend of mine has his own plane, we're flying straight in to Sebring. Plan was to leave Friday morning but if the weather sucks, we might leave a day early.... and there is always the chance that we decide to leave Weds night.
Don't get your hopes up though. I don't want to miss Sebring twice - I love that place!
Hmmm. I'll have to take a look. I know I noticed, the last couple times I've connected, that my own car's skin will randomly flash/reset (as if you hit CTRL-R and the car blanks white for a second as it reloads).
You're positive you switched it with TP? Does anybody else still see you as the pink pig?
#3712
I had this same problem when I switched to the Brumos livery.
I think if you open the preferences for the TP application from your task bar and check the box for delete skins after race this might fix it automatically, but I did it manually so it wouldn't delete all the other skins it had auto downloaded from members I had raced with.
Go to my documents then iracing/paint folder and then into the folders of the RUFs you want to delete the pink pig from. Look for the .tga file that has your iRacing customer ID (open it in a photo/paint program to double check it is the pink pig if you want) and delete it. Next time you launch iRacing it will replace it with the new one you selected on the TP website.
Hope this helps.
Hope this helps.
#3715
Sounds good. Maybe a shorter race? I have to fix my pedal set as i broke a mounting bolt avoiding a shunt last night !
Sent from NSA HQ using Rennlist Forums
#3717
I'm in....
