Sponsored By:
Sponsored By:
Cayenne Coding - The Ultimate Guide & Discussion
Old 01-10-2021 | 12:56 PM
  #901
rainer's Avatar
rainer
Talking
Don,
that made my day...
I was not aware he has a naturally aspirated engine, else I would not have replied on coding this feature the way I did ..
cheers
Ray
Originally Posted by deilenberger
There is no "absolute pressure" in an intake manifold on a normally aspirated car. There is a vacuum when the engine is running. You can measure it with a simple vacuum gauge which references it to air-pressure at sea-level (1-bar). If you're looking to measure the local air-pressure vs sea-level air-pressure, you'd use an altimeter. There is no way to "code" this into the ECU on a non-Turbo Cayenne and display it on the dash because Porsche understands this.
That's it for me. There is an "ignore" feature on Rennlist - you've made it to my list of people I simply no longer see or hear from.
Old 01-12-2021 | 11:47 PM
  #902
ArmyRover's Avatar
ArmyRover
Originally Posted by JB911
But search, there might be other sources that sell the navigation disc. Please post results-
Will do my Launch finally arrived and it is pretty amazing so far.
Old 01-13-2021 | 01:06 AM
  #903
JB911's Avatar
JB911
I've been all over the place deciding what to get. The PIWIS laptop or tablet complete, II or III, or the Launch X431 Torque or Turbo. Then, I started looking at the Autel 906BT again. I see in the Ferrari chats quite a bit of talk, and the Launch Tech USA Torque version is the one many are using. The X431 Torque is probably equivalent to the X431 V+ Global version. So far, before even buying it, LTUSA has not answered any questions. Maybe they're on a very extended Christmas vacation
Searching for the 906BT Porsche and Ferrari users didn't yield much but I'm still trying to look at all features to compare-
Old 01-13-2021 | 10:47 AM
  #904
JB911's Avatar
JB911
I took some screenshots from the service manual in case it helps
Old 01-13-2021 | 01:40 PM
  #905
don16's Avatar
don16
It's live, please please help out and subscribe to my channel and share to your friends and family:
Old 01-13-2021 | 01:41 PM
  #906
don16's Avatar
don16
If you want me to make more coding videos let me know
Old 01-13-2021 | 02:30 PM
  #907
imalek's Avatar
imalek
@deilenberger thank you for the web copy paste for the definition of the absolute pressure, it was a waste of time to explain it dear. To answer your question, yes I am looking to show what the MAP sensor measure, there must be a variable that capture this and send it to the ÉCU, I was wondering if this can be coded or requires hard programming. (The idea again is to go out of the box).
@rainer , yes my car is a naturally aspirated, I mentioned that before, you might missed it.
Old 01-13-2021 | 08:07 PM
  #908
dollarlongnecks's Avatar
dollarlongnecks
Old 01-13-2021 | 08:16 PM
  #909
JB911's Avatar
JB911
This vendor has the PIWIS III with Lenovo laptop, free shipping-
https://www.uobdii.com/wholesale/por...-software.html
Others have the Lenovo Yoga, not sure which one is better(?)
Still considering X431 Torque or the new Turbo
Old 01-13-2021 | 08:26 PM
  #910
911-997's Avatar
911-997
Buy PIWIS ii. Unfortunately I learned this the hard way. I bought x431 pro thinking it will do same thing as PIWIS but I did some retrofits on the car and alot of features you cannot program on car for adding new modules using x431 pro
Old 01-13-2021 | 08:32 PM
  #911
twodollardoug's Avatar
twodollardoug
Being able to use the x431 on cars other than Porsches was my deciding factor. And being in English.
Old 01-13-2021 | 08:34 PM
  #912
siberian's Avatar
siberian
x2, plus two years of free updates and I've yet to find something I can't do on the x431.
siberian
Old 01-13-2021 | 08:42 PM
  #913
911-997's Avatar
911-997
siberian
Try coding the following:
1- Adaptive cruise control
2- Initialize steering wheel angle sensor (when you retrofit heated steering wheel and use different clockspring)
(Guaranteed you wont be able to use x431 for them)
Then lets revisit your statement
Old 01-13-2021 | 08:45 PM
  #914
siberian's Avatar
siberian
The number of times I would need that (I've retrofitted a heated steering wheel on my Touareg with a VAG-COM - as to the steering angle it corrects itself by turning the wheel far right and far left; but hey it's a VDub) pales by the number of non Porsches that I get to work on. To each his own as I said, two years of free updates 10,000 vehicles covered, statement revisited
siberian
dollarlongnecks (01-17-2021)
Old 01-13-2021 | 08:56 PM
  #915
twodollardoug
siberian
X2
Quick Reply: Cayenne Coding - The Ultimate Guide & Discussion
