Cayenne Coding - The Ultimate Guide & Discussion
#784
#786
I really want to see someone post up the module info on a Cayenne that allows the rear lid to close from driver door panel. If part is different, I can then assume I need that newer module or reprogram mine to that of the other module. Maybe they can even backup configuration from their module and send it over so I can try restore.
Anyone out there?
#787
Definitely, I did see some mention of VW and Q cars in the menus.
Anyone out there?
Anyone out there?
Happy to share the XML file which is from a control unit replacement procedure.
#790
Got bored so decided to rescale the gauges correctly. Used a few online dyno graphs to get the points correct. Haven't worked out yet how to remove 9 and 10 from the bottom, I zeroed them but they still show. Also the orange ball still only goes left to right and not up and down aswell as it should. Really need someone with the new 718 or 911 to check the coding to see what's missing etc.
#793
#794
Hi Sterod,
if there is no turbo in the car, the max boost pressure can appear, I tested it on my car, it is listed. The issue I am not able to make it work, this requires some coding it seams. Did you succeed to make it show boost pressure?
