Cayenne Coding - The Ultimate Guide & Discussion
#1607
BCM Vorne E2 Max GT5 / Coding Value / Allgemein Verriegeln mit akustischer Rückmeldung - Change to Ja
rainer (04-24-2024)
#1608
#1609
The best solution I have found is to set the start stop to activate to last setting on restart via X431.This eliminates the need to press the button on every start up. I don't believe anyone has found a way to totally disable it.
Just read you have a 2019 so not sure if possible on this model
Posting some screenshots to help you. But wanted to let y'all know it's totally possible and pretty easy once you poke around and know what you doing. The interface is a bit unintuitive, not gonna lie.
The key for me was going into "SYSTEM SELECTION" from the diagnostic report. Not at all obvious.
Good luck
#1610
Ok so I got stop start disabled with an X431!! I'm so happy!
Good luck
Good luck
#1613
#1614
No, I believe it's a unique tone the PCM makes with a Bluetooth connection from an Android phone. Both my Cayenne and 991.2 make the same sound. Changing the tone on the phone does not change what sound the PCM makes when getting either an SMS or e-mail notification.
#1615
Good luck
Good luck
siberian
#1616
i tried looking for Windows Comfort on my 13 CD but i only see Acoustic Feedback but no windows comfort inside Front End Electronics
No window comfort under front end electronics
comfort entry windows up/down via keyfob coding
hotrod2448 and Eskimo1, this is for you. It was located in the front-end electronics module.
Attachment 1345071
Attachment 1345072
Attachment 1345073
https://youtu.be/8jNqjudQneU
Attachment 1345071
Attachment 1345072
Attachment 1345073
#1617
For my 2017 GTS, I only coded 1 setting in the Air Conditioning menu for the Auto Stop/Start and it seems to be working so far.
I was unable to activate the auto fold mirror function. The OP directions seems to be for 2016 and older models with PCM3.
Anyone figure out how to code the ambient lights in the doors to work without having to run all of the other lighting that comes with that feature?
#1618
#1619
@TurtleMountain how did you turn the Turbo Boost gauge on? Did you do this on x431 or piwis? I only have access to piwis
#1620
I would have thought that if x431 can do this so can PIWIS 2/3 but it might need to be done in developer mode? I'd be interested in how this was done as well.
