View Poll Results: Poll: Have you had bore scoring on your 997.1 or 997.2 engine?
Yes, 997.1 (05-08 MY)
143
14.50%
Yes, 997.2 (09-12 MY)
18
1.83%
No, 997.1 (05-08 MY)
524
53.14%
No, 997.2 (09-12 MY)
301
30.53%
Voters: 986. You may not vote on this poll
Poll: Scored cylinder failure for your 997, Y or N? tell us (yr, 997.1 or 997.2)
#391
Sorry to hear! It definitely goes to show that you can have very advanced scoring and show zero symptoms, which only means that we are all driving around with scored engines...most just don't know it yet. Yikes.
How are you going to handle the rebuild? It seems like depending on the route you go, it will be a few months without the car if you go with a local builder and probably as long as 2 years if you elect an FSI build. They seem to be filled for this year and have a growing waitlist.
#392
#393
I'm based in Europe and I am fortunate enough to find specialists (with 40y+ of experience on Porsche engines) who can carry out the rather complex operation.
It's not going to be cheap though
#394
Ugh, sorry to see this. That looks pretty advanced and like others, I'm surprised there were not noticeable symptoms of bore scoring from looking at those pictures.
Just curious if you ever had a used oil analysis performed and if so, what the aluminum levels were? Obviously there is no point in having that done now that you have confirmed scoring, but I'm curious if high aluminim levels in the oil could be an indicator of scoring while the engine is still asymptomatic.
Yeah, the price of a rebuild is what makes hearing these stories so painful. You'll have a better, probably more powerful, more reliable engine when it's all said and done, but stroking that check is the hard part.
You'll be in great hands with Hartech. Along with LN Engineering and Flat Six Innovations here in the states, Barry ("Baz") has been one of the leaders in identifying the design flaws of the M9X engines and coming up with solutions to help prevent failures, along with a great way to rebuild these engines to make them almost bullet proof going forward.
Good luck.
I'm planning to go for The Hartech Porsche Engine Rebuild Approach, essentially stripping the engine, new nikasil coated cylinders & cylinder heads, and then put things back with new OEM parts such as bearings, distribution, oil cooler gaskets, bolts, etc Ohhh and also install a new cooling system (which opens at lower temperature)
Good luck.
#395
Good luck.
Good luck.
By the way, this is how my engine sounds (in a previous recording to try to identify what appears to be the sound of a struggling pump):
#398
#399
To my eye that doesn't look bad and not something I would be alarmed either. I received very similar images from a PPI when I got my 40th anniversary 996. My course of action will be to just follow best practices for warming up the car and replacing some parts that can contribute to scoring, like leaky injectors.
#400
Ive done numerous "invasive" PPI's on 997's, both .1 and .2, and I must say that the poll data does NOT reflect what I see in my shop. My anecdotal observation is that easily >50% of either M96/97 or 9A1 will have scoring. Not "scuffing" (which is early stage scoring in any case) but full on scoring, at 12 and 6 o'clock, on every hole in the motor. 12 o'clock is typically more aggressive than the 6 o'clock.
#401
#402
#403
If the car is in the shop at the current owners behest, the path forward hinges directly on the severity of the scoring. As people have posted here, many of these cars with mild to significant scoring appear asymptomatic. No excessive oil consumption, no black tailpipe soot, and no ticking. Of course I have seen cars that sounded like the next time you started it may be its last, the owner had assumed it was "typical of a 911", and has been driving it like that for years.
What a particular owner does varies by their wallet thickness, the car in question and how they see Porsche ownership. I have yet to see someone with an early Cayman S fix anything- the repair cost is the value of the car. They drive the hell out of it, knowing they will sell it later, and (I presume) hope the next buyer is clueless as to possible issues.
911's are clearly a different matter as their values are far higher. True believers will budget and fix, increasing capacity as an unintended "upside". Owners who bought the car because of the little gold thing on the hood will often just trade it in at a dealer on another marque. Which, brings me to a rule: If you see a Porsche at a Ford dealer (as an example) dont even bother looking at it. Chances are near 100% its there for the aforementioned scenario.
Carreralicious (03-03-2021)
#404
What confuses matters, for everyone, are the outliers. The '99 C2 with 22k whose oil has been changed perhaps 5 times in its life, or the 150K mile '10 C4 with bi-annual oil changes - both of which may look new in the bores.
I have pictures, but Im not sure what value they have to be posted- there is no shortage of grey fields with black and silver streaks in them.
#405
This is impossible to know but I'm curious about the owners of the cars that had bore scoring. Are they the owners of garage queens that do not get driven much, annual oil changes at best and idling the car for extended periods of time combined with short trips? All these are known contributors. I DD my car and there are many others that do, although that may be different in CO, but not impossible and unheard of. It's been proven many times that not treating a car like a car and more like a museum piece is in line with these and other issues. Not specific to Porsche. Just ask Ferrari owners about a belt and seal service with engine out after 3k miles over several years.
We are at a point where these cars are becoming more affordable to buy (but necessarily own) and the 3rd, 4th, 5th owners are the benefactors of the 1st or 2nd owner cars that didn't treat the car like a car.
advrider1967 (03-03-2021)
