Duramatric Programming
Old May 15, 2013 | 11:22 PM
  #61
Petza914's Avatar
Petza914
bgrpph, I've been wanting to correct this functionality for a while now and just didn't know what the proper settings would be. Thanks for the post!
Old May 16, 2013 | 01:56 AM
  #62
socalgt3's Avatar
socalgt3
Thanks bgrpph for the update!
Old May 16, 2013 | 02:02 AM
  #63
USMC_DS1's Avatar
USMC_DS1
Excellent bgrpph... this is the other "white unicorn" feature many of us have been chasing.
Old May 16, 2013 | 09:01 AM
  #64
Coochas's Avatar
Coochas
Originally Posted by bgrpph
my 07 911 turbo--- was able to turn off the seat belt chime (as shown earlier in this or another durametric thread)- but had issues trying to get my windows to go up/down using remote lock/unlock- finally got it working- just wanted to let folks know that to turn this on with pro model you follow coding under alarm to set comfort function window to active and also comfort function remote to active. However under left door & right door you must set the comfort closing and comfort opening to OFF - or inactive- earlier in thread it says to set to on but this is wrong- set it to off and your windows will close when you lock the car with remote and open when you open car with remote- (can also set sunroof if desired)-
hope this helps someone
I will try this later. For the life of me I haven't been able to make the comfort windows thing work. I hope this works on my car!
Old May 16, 2013 | 09:39 AM
  #65
slicky rick's Avatar
slicky rick
Had this feature activated using the piwis. Just have to go back and activate the sunroof too.
Old May 27, 2013 | 11:17 PM
  #66
Petza914's Avatar
Petza914
Default Comfort Windows
I finally got a chance to try and correct the key fob opening and closing the windows feature, and for me at least on both my 2005 C2S cars, bgrpph's info got me closer but not all the way there. On both my cars, I had to set the Comfort Windows in ALARM to Active and in both the LEFT DOOR and RIGHT DOOR modules, I had to set Comfort Opening to OFF, but Comfort Closing to ON. When I set both to OFF, the windows open during the Long press of the Key Fob when unlocking the car, but do nothing with a long press when locking it. Changing the Comfort Closing setting back to ON, now has both my cars fully functional. I opted not to tie the Sunroof in since I sometimes like to leave that in the up vent position to let heat out in the summer but want the windows to close.
Hope this extra info might help some of you still struggling with this to get it working.
Pete
Old Jun 6, 2013 | 07:28 PM
  #67
jhbrennan's Avatar
jhbrennan
Originally Posted by Luxter
Not true. Side markers become signal lights in addition to front and rear signal lights.
Side signal lights make much more sense in heavy traffic.
Cheers,
=L=
Finally did this and what happens is that side markers stop being side markers but do function as turn signals along with the front turn signals.
Old Jun 8, 2013 | 09:59 AM
  #68
jgoga's Avatar
jgoga
This worked for me. Anybody know how to get the sunroof to close and open? I tried the comfort function windows and sunroof active feature but nothing happend, under the alarm. Is there a diff area that i must go for the sunroof besides the alarm?
John
Old Jul 25, 2013 | 10:01 PM
  #69
d0lph1n's Avatar
d0lph1n
Do you know where I can rent or borrow one in Orange County, California?
I'm just interested in:
- Enable side Markers to blink
Thank you
Old Sep 8, 2013 | 04:16 PM
  #70
cup997laurent's Avatar
cup997laurent
I retro fitted the tempomat on my 997-1 C4S , but have problems with coding it, I found three difference location where I can enable it with my Durametric tool but it didn't work. Did someone tried to do this ?
Old Sep 8, 2013 | 06:55 PM
  #71
slicky rick
Still waiting for someone to share how to tie in the sunroof to open and close with the door using the remote fob. Seriously can this feature be done?
Old Sep 8, 2013 | 07:06 PM
  #72
windboat's Avatar
windboat
Try this solution, http://www.mods4cars.com/sms/shop/in...ode=view&id=49
Their SMARTTOP is highly regarded by P-car CAB owners. Very easy DIY install.
Sent from my iPad using Rennlist
Old Sep 8, 2013 | 10:25 PM
  #73
jhbrennan's Avatar
jhbrennan
Back in May you said you were going back in to have PIWIS do this. I guess they couldn't do it either?
Old Nov 22, 2013 | 05:05 AM
  #74
Egress's Avatar
Egress
7th Gear
Sorry to revive an older thread, but has anybody encountered a problem where the seatbelt chime returns, even after disabling it? I have disabled it using both the Durametric and PWIS but the seatbelt chime comes back after the first time I drive off.
Old Nov 22, 2013 | 11:24 AM
  #75
Bruce In Philly's Avatar
Bruce In Philly
What year is your car, and do you have Sport Chrono?
I discovered that in 2009 (I have a 2009 C2S) that some settings are overridden due to not having Sport Chrono. I do not have SC, and I can't set the auto locking. It resets after I restart the car. Same thing happened when the Porsche tech tried it with the PIWIS. I was with him and he said "that shouldn't happen". He called Porsche..... anyway, it may be resetting a swath of flags. Also, I can not get the comfort window settings to work and I suspect SC on this one although I have no proof.
Or...... IF Porsche got sneaky with the door lock etc and makes then reset, they may have done that for "safety" items as well.
When folks have posted their Durametric work, I usually don't see the year of their car so it is tough to get good data on this.
Peace
Bruce in Philly
