Duramatric Programming
#106
Hi all, instead of starting a new thread i figured i'll continue this one.
I have 06 Carrera 4, 6spd with chrono, nav, no cd.
Just got D Pro a few days ago and installed software on MacBook running windows 7.
When i connect to the car and select Non-Turbo 05-08 in Duramatic menu i get a list of all the Modules and under AWD it tells me the module might not be installed.
Somewhere else in the menu i noticed that type of car is set to C2S instead of C4.
Can i safely change it to C4?
Also tried to activate the Chrono to be on all the time and as soon as i leave the screen where you start the lighting for chrono it turns off.
Also while browsing through all of the items very often my Duramatic app freezes.
Any thoughts?
Any thoughts?
#107
Can i safely change it to C4? Yes absolutely - can't remember if/how you do this though.
Also tried to activate the Chrono to be on all the time and as soon as i leave the screen where you start the lighting for chrono it turns off. That's because it's only an activation, not a setting.
Also while browsing through all of the items very often my Duramatic app freezes. Yes unfortunately it does this a fair bit.
Any thoughts?
Any thoughts?
#108
Thanks much. Any way to have Chrono on all the time other than starting it and letting it sit paused?
Also, any idea if i will screw something up by killing the App and reopening it all the time when it freezes? I just hope it doesn't happen when its writing to the module
#109
What VM software are you using? I have used Parallels with Win 7 and never had any free up issues.
#110
Just got a Pro kit yesterday.
For me, comfort closing and opening required the Left door and right door settings to be "off" for comfort closing and opening (oddly). Just needed to active comfort closing and comfort remote under alarm.
the flashing airbag light to disable the seat belt chime is annoying, but oh well.
#111
Im using bootcamp and just double boot the machbook pro. so i would say its a native install?
#112
hi phil, was this for an updated front control module???
I tried to replace the front module and even if I set all the settings manually the same as the old one it would not function correctly.
Owen looked at the log file I sent him about restoring the settings and they can see an error happening and are looking in to it.
Durametric is still worth it to me, although I'd really like a guide as to what all the settings do.
#113
Just bought the Enthusiast version. What a tool! Should be mandatory buy for any DIYer!
I was going through the activations and noticed that there is a brake bleed activation. Are you telling me that I can attache my catch can, crack the bleed screw and just hit START? No more hooking the pressure bleeder up?! Does the computer know the resevoir level so you cant get it too low and introduce air? This is life changing for us track guys!
#114
