What did you do to your 997 today?
Old 05-29-2021, 05:21 PM
  #11746
Elonash
Elonash's Avatar
Today I added protective grills in the front bumper.
Based on the various diy's available here and there I purchased a stell sheet in a local shop.
I plastidipped it and used a multi-purpose sealant in some spots, no screws.
As I don't really like the look of the central grill I made two small pieces that goes on each side of the central inlet.
Very happy of the result !
Elonash is offline
Kineticdg (05-29-2021)
Old 05-30-2021, 04:00 AM
  #11747
Happy2th
Happy2th's Avatar
Ceramic coating, full front PPF and changed the amber to clear indicator.
Happy2th is offline
The following 7 users liked this post by Happy2th:
ABNJOE (05-30-2021), Bomar Shelby (05-30-2021), EMC2 (05-30-2021), Hootsama (05-30-2021), Ironman88 (05-30-2021), JAAM (06-09-2021), rtl5009 (05-30-2021) and 2 others liked this post. (Show less...)
Old 05-30-2021, 11:48 AM
  #11748
Skube
Skube's Avatar
Not technically all done today, but making the completion of this project, started with a slipping clutch and removing the calipers to have them powder coated, and ended by replacing pads, rotors, clips, hoses, bolts, sensors, and a few other things, but I am very happy with the end product.
While it was in the air I took the time to install the EMC2 front lip which went on easily and looks fantastic.
And finished the project with a new set of floor mats to continue to add some black accents to my beige interior.
Now on to the next project, new control arms, struts, and lowering springs.
Skube is offline
The following 9 users liked this post by Skube:
ABNJOE (05-30-2021), Dubber (06-07-2021), Hootsama (05-30-2021), Ironman88 (05-30-2021), JAAM (06-09-2021), nydog (06-03-2021), Ohio Performance (06-01-2021), RockyTop (01-30-2022), uncle_sam (05-30-2021) and 4 others liked this post. (Show less...)
Old 05-30-2021, 11:57 AM
  #11749
Bomar Shelby
Bomar Shelby's Avatar
Happy2th ,Sweet car, we have simiar taste
e
Bomar Shelby is offline
The following 2 users liked this post by Bomar Shelby:
Happy2th (05-31-2021), Ironman88 (05-30-2021)
Old 05-31-2021, 03:32 PM
  #11750
rtl5009
rtl5009's Avatar
Replaced the oil pressure sender. The harbor freight crows foot works but needs ground thinner to slide in. Just FYI. Built a targa too.
rtl5009 is offline
Old 05-31-2021, 03:42 PM
  #11751
nydog
nydog's Avatar
Oil change, wash and spray waxed, changed rear brake pads, installed new windshield wipers
nydog is offline
Old 05-31-2021, 04:26 PM
  #11752
PCARNTHZST
PCARNTHZST's Avatar
I installed JoyeAuto (Apple Carplay system). What a terrific update for the 12 year old car PCM.
PCARNTHZST is offline
The following 3 users liked this post by PCARNTHZST:
BLU997 (05-31-2021), irnnr (06-01-2021), vg247 (06-01-2021)
Old 06-01-2021, 01:45 AM
  #11753
vg247
vg247's Avatar
Was it an easy install, or did it require a lot cable splicing etc?
vg247 is offline
Old 06-01-2021, 07:42 AM
  #11754
PCARNTHZST
PCARNTHZST's Avatar
Plug and play, no splicing. It took me 2 hours. The hardest thing I had to do was hid the Joyeauto box. I ended up stuffing it at the end of the passengers side footwell behind the glove box just above the carpet line. Pretty easy access should I ever need to get to it again.
If I decide to add a rear view camera, it should be as simple as running the additional wire to the back and flipping a dip switch on the Joyeauto box since the wiring comes with the kit already installed.
The following 2 users liked this post by PCARNTHZST:
vg247 (06-01-2021), VT Blue (06-06-2021)
Old 06-01-2021, 05:32 PM
  #11755
Climarepair.com
Former Sponsor
Climarepair.com's Avatar
Nice!
Climarepair.com is offline
Old 06-01-2021, 08:01 PM
  #11756
andy93si
andy93si's Avatar
New wheels day. Found these for a deal too good to pass up.
andy93si is offline
The following 7 users liked this post by andy93si:
ABNJOE (06-02-2021), AxelR (06-01-2021), BLU997 (06-05-2021), Huaco (06-01-2021), JAAM (06-09-2021), shyamvenky (06-02-2021), TerrestrialFlyte (06-04-2021) and 2 others liked this post. (Show less...)
Old 06-01-2021, 11:24 PM
  #11757
BucketList
BucketList's Avatar
Took a few days off and detailed my ride. Full cut and polish using Menzerna 400 and 2500. New Stone guards in black. Ceramic on paint and wheels with Bead Maker after that. Also installed radiator grills. I may add side stripes later that stop at the door edge but I am still wrestling with that idea. My daughter bought them as a present so there is that...
Left the nose alone because it's pretty beat up and I am going to wrap it and I want to black out the old radiator guards so they disappear. I am loving the ceramic. The pics don't do it justice.
BucketList is offline
The following 3 users liked this post by BucketList:
ABNJOE (06-02-2021), nydog (06-03-2021), Ohio Performance (06-02-2021)
Old 06-02-2021, 05:11 PM
  #11758
arscottp
arscottp's Avatar
Back on the ground after H&R spring install. Slowly working on the interior. 991.2 oem carbon steering wheel, carbon shift ****, black alcantara boot, black center console and ebrake.
arscottp is offline
The following 10 users liked this post by arscottp:
ABNJOE (06-02-2021), DougNuts (08-28-2021), Dubber (06-07-2021), frederickcook87 (06-11-2021), JAAM (06-09-2021), Motopilot (06-06-2021), Presto (06-05-2021), rtl5009 (06-02-2021), Skube (06-06-2021), TerrestrialFlyte (06-04-2021) and 5 others liked this post. (Show less...)
Old 06-02-2021, 05:32 PM
  #11759
Darkhorse
Darkhorse's Avatar
Default 997.2 IPD Plenum etc
A couple of people asked about the IPD plenum on my 997.2 C4S. It's a six speed with Numeric short shifter and cables. I installed the IPD plenum and BMC filters when I installed the Sharkwerks by-pass pipes in 2019. I think the combination works well. It's a little more free flowing on each end. I think the combination works well. The throttle response is more immediate and I think the RPMs grow faster now. I have a Cobb Accessport but have not installed the tune yet.
Darkhorse is offline
The following 2 users liked this post by Darkhorse:
ABNJOE (06-02-2021), PCARNTHZST (06-02-2021)
Old 06-04-2021, 12:52 AM
  #11760
Dpmarc
Dpmarc's Avatar
Vinyl headlight trim an Getty ducktail sport test fit 👌 now time to paint!
Dpmarc is offline
ThreeFiftySix (06-04-2021)
Quick Reply: What did you do to your 997 today?
