What did you do to your 997 today?
#8716
Got out for a short drive ...
#8717
Do you have .1? If so, how difficult is the accelerometer installation for the DSC? I have been contemplating on this mods.
Installed H&R lowering springs, Michelin Pilot Sport Cup 2 (245 and 305 'Track Connect' versions), 6mm compensation plates on front (nothing on rear), RSS 15mm spacers front and rear, and DSC Sport controller - the DSC controller makes a pretty significant difference to daily driveability - Sport mode used to be teeth crunching, now, it's completely doable, even with the H&Rs and crappy Houston roads. Using the 6mm compensation plates has evened out the drop - a lot of pictures of H&R springs showed less gap in the front, I feel mine is very even (Part number 996-343-511-00)
Also did RSS engine mounts, and DTX transmission fluid - gear changes are noticeably easier, it feels like the whole gearbox has loosened up. Oil change and filters also completed.
The gif is a before and after: Stock PASM on 'small' tires, vs H&R springs and 'meaty' tires (I would use 'CRTL+' to zoom in)
https://media.giphy.com/media/WRjVYE...bfVY/giphy.gif
#8718
It took about an hour. It's quite fiddly as the wiring looms are wrapped tightly together. The hardest part is getting used to the idea of cutting wires - so I didn't, I bought two packs of these instead:
This way, the wires are never cut,and I can remove the accelerometer and run some tape over the holes if I return it to stock.
You also have to be careful which wires to tap in to - there is a red/grey and grey/red in the same harness...
#8719
Cw
#8720
Cutting wires is also my biggest concern with this mods but thanks for the insight.
I am in Houston also and we should swap stories sometime
It took about an hour. It's quite fiddly as the wiring looms are wrapped tightly together. The hardest part is getting used to the idea of cutting wires - so I didn't, I bought two packs of these instead: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#8722
Decided to switch to Driven DI40 so did the initial flush with DT40, rotated tires, and replaced the clutch switch which has given me a few "depress clutch" errors/non starts in the past few months. 12k miles on my 09 and the switch was still original, so more of a preventative repair.
The following 2 users liked this post by mujeriega:
latonnelier (08-07-2019),
Presto (08-09-2019)
The following 2 users liked this post by 997v2cabrio:
Quicksilver997S (08-11-2019)
#8725
Basic Sponsor
Hey nice intake!!
#8726
Originally Posted by mujeriega
Took my daughter to her first day of kindergarten this morning in my 997.2 Was funny to see that I had the only sports car in a parking lot / sea of SUV's and minivans.
#8727
Installed a new 991.2 steering wheel into my 2009 C4S, super easy and made a ridiculous impact on the interior. Also...as you'll see in the pic with the new steering wheel, my TPMS light is on...I had all four TPMS sensors replaced with ones i bought on TPMSdirect.com, had them installed with new tires last week, TPMS system still not working...bought used TPMS control module from a fellow rennlister in the classifieds, installed the new module today right after putting in the steering wheel, went for a 2 mile drive and BAM!!!! TPMS is NOW WORKING...amazing day for sure. Notice on the second picture all TPMS readings are there AND there are ZERO DASH LIGHTS!!!!!!! what a great day to own a porsche! (the pasm dash light is on because i had the battery disconnected while installing the new steering wheel/airbag combo)
Note the dash lights for the TPMS sensors, i installed the steering wheel about an hour ago...
Then i installed the TPMS Control module about 30 minutes ago and went for a drive...booyah. TPMS works and dash lights are GONE!
myw (09-23-2019)
#8729
Looks fantastic! Where did you get the wheel, and if you don't mind how much was it? Rare to see a 991 wheel that doesn't have all of the multifunction geegaws - much cleaner.
#8730
I bought the wheel off eBay from a seller called 911ava and found this combo, it was the steering wheel, the correct internal wiring harness, and the new airbag for 1600. It was soooo worth it for me. i could not stand the stock steering wheel. They look so old and dated. The difference this new one makes is staggering. I do also have a 991.2 wheel with the multifunction buttons too though haha! I might end up putting that one on and adding a porsche gps tech box to add multi functionality use with my PCM.
Edit: I will say too, the installation of the wheel takes about 5 minutes. Not kidding. You pop the airbag off, unclip the harness, unscrew the 55 Torx bolt, swap wheels, plug in the harnesses and torque the 55torx bolt back in. Job done. Sooooo easy.
hamishpotter (08-09-2019)
