What did you do to your 997 today?
#5674
Looks great and really good color match from this angle, but the gap between the decklid and bumper is too wide.
You need to lower the latch attached to the inside of the bumper in order to lower the decklid so it narrows that gap. Easy to do. Two screws to loosen. move the latch down and tighten the screws.
#5675
It looks nice, how difficult is it to remove the rear wing? I want to repaint mine, some areas starting to crack.
#5677
Removing the engine deck lid is easy. Remove the two bolts on each side of the hinge and disconnect the electrical harness at the large connector at the upper right of the engine bay. Disassembling the engine lid and prepping for paint is where all the work begins.
#5678
Nice! thanks, yeah, didn't think it was too difficult, figure I'd asked since you've already done it.
#5679
Gundo hack. Finally, after 2 years of ownership. Had Vision Motorsports in Laguna Hills, Ca do it, on the recommendation of a friend. It sounds really good now.
Also, I put in 5mm spacers (ECS tuning) on the rears- I probably could have gone more, but it looks good to me.
#5680
Highly recommend pairing the Gundo hack with an x-pipe (Sharkwerks/Fabspeed). Sounds sublime. Best mod I've done.
#5681
#5682
#5683
#5684
The cold start is a bit loud for 20 sec but I just leave the garage shut for that.
#5685
