Note to Porsche classic - 997 PCCM plus request
#1276
Hi All, Just fitting my PCCM+ into my 997 tip and have got the reverse camera working. As a test I connected and old camera with av out. I took the video out from the camera and connected it to a fakra to rca adapter. As you can see from the picture the car is in reverse and the camera output is on the screen. Hope this helps. Shaun
#1277
He just plugged a fakra to rca adapter and then plugged an ab connector into that - and put the car into reverse. That’s it
#1278
to do a test, u just insert it in the hole - but for a permanent solution you will need the proper wire tool - or soldier it in directly.
Im considering releasing a harness + cable kit + camera kit - which will include whats necessary to get a clean non-shared GND connection for the camera itself - minimizing (almost all) splicing.
The following 6 users liked this post by myw:
brudomen (02-13-2023),
dlascoskie (02-14-2023),
fritzcurtis (02-14-2023),
funcars (02-14-2023),
maxw (02-14-2023),
and 1 others liked this post.
#1279
The following 3 users liked this post by brudomen:
#1280
So that I don't have to do all the things you described above with PIN 6 PIN 8 and additional cable etc. with a Tipptronic. Right?
#1281
Please understand that beebman's post is a videoCamcorder device having it's own power source - it was merely a fakra/rca input test only (not requiring camPower or camGND).
#1282
#1283
pin 6 no - but pin 8 yes yes of course you do. Or you can choose to power the cam using the other methods mentioned in this thread. Don't forget you will still need to GND the camera as well.
It was only important to me to understand that I don't need all this wiring **** on my harness with my car with Tipptronic.
myw (02-14-2023)
#1284
Just wanted to say thanks to @myw , @svandamme & everyone else who helped with this process so far. I put mine in last night and had a great drive to work this morning! This thread and the diy writeup were helpful. I didn't add a backup camera yet, but will eventually go back in there and do it. Anyway...highly recommend it to anyone on the fence about getting the pccn+ and Guadin in Vegas still has them avaiable.
The following 5 users liked this post by dlascoskie:
Ditchhanger (02-14-2023),
maxw (02-14-2023),
myw (02-14-2023),
Nova997 (02-14-2023),
svandamme (02-14-2023)
#1285
Does anybody know through which pins to power the PCCM Plus? I want to test it outside the car by using the trickle charger in 12V supply mode. Thinking of testing the backup camera through this setup.
#1286
#1287
@svandamme I have looked at it but have failed to identify which are the pins for power to the unit.
Is it 22? I am not quite sure. Obviously I asked in case someone has tried it and knows the answer.
#1288
definately not 22. That’s for the fiber optic unit - 500ma which is way too low to power the pccm.
I would suggest looking for the thickest red or yellow wires on the main harness to start
#1289
The smallest (from what I recall) reverse cam I could find. I have run the prev 480p and now AHD version of this camera.
Very discrete and is drilled into the center of the bumper using a 20mm included cutting tool. It’s hard to see.
here is the first gen license plate bulb type of camera - I removed it shortly after the install. I didn’t mind that it’s off to the side (and didn’t really notice the rear image being off to the side) but it was just so visually clunky on beautiful rear end.
bxstrCA (03-27-2023)
#1290
Thank you very much for this statement. That was important to me. Of course, I am aware that the reverse camera needs its own power connection and GND. Here I wil use my reverse light.
