Note to Porsche classic - 997 PCCM plus request
#1066
[QUOTE=svandamme;18609564]
Of course, it's good if it's running.
But there are many things in the software that can still be improved. And there will certainly be a firmware update here at some point. That's what I meant.
#1067
there are cameras that simply fit in the license plate light.. no drilling required.
Porsche uses VW style License plate lights and those are on aliexpress
https://nl.aliexpress.com/w/wholesal...home.1000002.0
personally i'de rather use one of those than drill a hole imma rear bumper
i ended up buying , which again has the same angle issue, but it is not one solid, molded piece like most of the aliexpress ones. i used a fine saw to cut it, rotate the camera position, then epoxy it back together. i left a review on the listing, will not be hard to figure out which one as mine as there are pictures of the deep blue pearl R. the review i left is before i modified it.
view before rotating, and what you can expect without modifying:
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_6706_d3295c9155a7c95f0775d01ee478c4114dc74d24.jpeg)
view after my mod
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_6711_9716f015492896d15b9f765a92883764143b991b.jpeg)
#1068
i have experience with this in my R32 as i added a RVC to it recently. off the bat the problem with most of these is they angle down. the R32 license plate is in the same position as the 997, which is low on the rear bumper. you are putting in a camera a couple feet off the ground that is also angled down. granted, these cameras have a wide field of view, so you can still see behind you decently well but i didn't appreciate that a big chunk of my view was staring at pavement.
i ended up buying this model, which again has the same angle issue, but it is not one solid, molded piece like most of the aliexpress ones. i used a fine saw to cut it, rotate the camera position, then epoxy it back together. i left a review on the listing, will not be hard to figure out which one as mine as there are pictures of the deep blue pearl R. the review i left is before i modified it.
view after my mod
view after my mod
So for me, the view without modifying seems to be just right. So I can see the things that are immediately behind my bumper. For example, small children and obstacles when parking.
TerrestrialFlyte (02-04-2023)
#1069
Those things are not part of the Android OS, but on the widget designed by Porsche/the radio company
One can still get fixes on your accounting software that runs on Windows 7 , despite that windows 7 is EOL since 2020
the PCCM bits you deal with, the GPS, the MP3 player, backup camera, trip computer , those are not part of the Android bit
#1070
But let's be honest, if it's all the way you describe, then I'm out of it. If I can't play around with this new Android PCCM as I want, I can also stick to my old PCM 2.1.
Works great for me!
#1071
The comments on the operating software confuse me, this is a sports car we are taking about not a smart phone or gaming pc.
Surely all you need is a device to play back music at a good quality stream, up to date navigation and a reversing camera for those days you use your car in town!
After all this was a 100k car new, I expect parts and upgrades to match that level.
#1072
Okay, I understand. Then you think it's not a disadvantage that the PCCM only runs on Android 6.0? And Bluetooth in version 1.0? These are really old versions in a 2k bucks device from Porsche.
Works great for me!
Works great for me!
the functionality is there , its a big improvement over PCM2.1.. Clearly the lack of OS updates on PCM2.1 doesn't bother you, so why would it bother you on PCCM+?
its not a smartphone.
Its a car radio, and the functionality as advertised.. works. if not (like the satnav map in USA) , Porsche has to warranty fix it.. that's all that matters and has nothing to do with the android version.. its a non issue
whacko77uk (02-04-2023)
#1073
And besides, modern Android Headunits, are ultimately only tablets in a car. Why shouldn't I have the same demands as on my Pad that I am using at home?
#1074
By that reasoning why not buy the 992 generation, it the latest and greatest car and tech.
In my opinion Porsche have done it right, giving OEM look and functionality to a modern classic. They are at the end of the day a sports car manufacturer.
Tablets = Samsung, new one every year…disposable!
Apologies I did not mean to digress from what this thread is about.
#1075
Agreed. I’d much rather have half the screen taken up by what is in the immediate vicinity of my path than half of it taken up by the sky, which for a back up cam is useless (unless mounted on a helicopter, I guess).
medicus (02-04-2023)
#1076
Best regards
#1077
There is nothing confusing at all. The price of Porsche accessories is no problem at all. I would also pay $5000 for the PCCM. That's not the question. It is about Porsche, like any other manufacturer, installing the latest software and hardware when launching a new device. I demand that, nothing more, but nothing less.
Its not a pad..
Give me one example of an Android Radio that runs the latest Android, and allows you to download apps from the google store, like a pad does???
fritzcurtis (02-04-2023)
#1078
But that's not what I'm about, downloading apps. It would just be a nice gimmick. As I said above, I would like the technology of PCM 6.0 from the 992 in the PCCM for my 997.
#1079
Medicus please move on, clearly the PCCM+ is not for you. We want to keep the thread positive with people that are contributing in a constructive manner. No disrespect at all. Svandamme has spent a lot of time here helping many people out with their new PCCM+! You might check out alliexpress as there are a ton of alternatives that are clones that could potentially give you what you are looking for.
#1080
Well android version is not going to fix it if you want to do things on wifi, cause the wifi on the pccm+ is hardcode disabled.. and there is no simcard for wireless access.
indeed, clearly PCCM+ is not for you then, wishing a 15 year old car would do what a modern car has, I Don't think that is what Porsche Classic is about...
I guess for you , PCCM+ 1 din uinit for the older cars is also a complete waste , because despite the features, it won't make a 3.2 Carrera as modern as a 992.. right?
on another note, I removed the 2 top locking tabs off my pccm+ because those remain a royal pain in the neck for removal of pccm+
and for what its worth, they aren't needed.. the PCCM sits very snug with the bottom locking tabs and the center console side cheeks make it sit snug..
perhaps later after experimentation fase will i reinstall em, but for now i want easy of access to the rear
