Note to Porsche classic - 997 PCCM plus request
#346
looks like a mostHur Adapter.
otherwise I see
- gps adapter
- dab adapter?
- dual fakra antenna adapter
- main power harness (attached to what I believe is the antenna power adapter to turn the unit on)
- mostHur adapter as stated, it is great to see that it is beyond the standard stereo 2-channel mostHur adapters on the market meaning front/rear fader still works.
otherwise I see
- gps adapter
- dab adapter?
Spastblast (12-07-2022)
#350
but there are no usb ports - at best there may be a usb input harness that you would plug in, like all Chinese android decks.
Since the manual is out, id advise checking that out.
#351
since its a chinese android deck, you MAY be able to run a standard android pcm harness that has usb ports into the porsche pcm (assuming the port inputs havent been disabled via the OS).
No USB port on the back, gotcha. We will have to look out for some harness solution as you have mentioned. Thanks again.
#354
Edit:
Ah, too bad. Looks like a German owner just confirmed there's no USB on the back: "Es gibt keine Box wie beim 996 mit Aux und Co., der einzige Anschluss ist der USB Port an der Front"
Roughly translates to: There's no box like there is for the 996 (PCCM+). The only connector is the front USB port.
#355
Definitely was hoping there’d be a way to hide the USB, specifically to connect a wireless CarPlay module. However, for most of us, I’m guessing the reason we want this is because of the clean, OEM look that this is providing. I’ve seen many aftermarket head units on the market and even with the OEM bezel, it doesn’t look as clean as this one does. Not trying to argue with anyone, just my take. My purpose for buying is a clean OEM headunit and updated maps so that when I’m lost on a backroad, I don’t have to stop on the side of the road and get out my phone. I also don’t like to have a phone mounted in my car when driving. Driving is my one escape from the constant phone notifications so being able to silence my phone, connect it via CarPlay and have constantly updated maps is what I’m going for.
yvesvidal (12-08-2022)
#356
Originally Posted by Chris M.;[url=tel:18505070
18505070[/url]] $1000+ for wired CarPlay? No thanks.
Music quality is far superior and the phone gets charged as well.
You’re sitting in a car, WGAS whether it’s wired or Bluetooth?
#357
i went over the manual a few months ago - and since it confirmed it was a Chinese android device it made sense that like all Chinese android devices - have no physical rear plugs of any sort other then antenna + gps.
everything else (even microphone input) - are all dictated via harnesses + plugIns.
if the rear pin inputs are standard android device harness plugs - one can try either of the standard (i think 6pin or 8 pin) usb harnesses from another chinese android device and try to see if the pccm+ actually can read the usb inputs (assuming the usb inputs have not been disabled via the porsche OS skin software).
Have you seen the back of the device?
Edit:
Edit:
#358
the unit is as oem as I could get it too look based on some restrictions I had to deal with, my original design had it looking completely oem.
#360
