Note to Porsche classic - 997 PCCM plus request
#2326
The "chirp" from the Mods4Cars module that was set now no longer works. It appears that the PCCM+ must use one of the same "channels" (not sure of the exact word) that the Mods4Cars uses for it's activities /settings.
#2327
I used https://www.bergvillfx.com for mine. Even though they're in Norway, I had the amp back in about a week and the pricing is very reasonable. Would highly recommend.
#2328
#2329
USB/CArplay cables,still available
Thanks,Juha P, Germany,Car Porsche 997.1 GT3 2007
#2330
HI Ala, First thank you so good forum and info for this upgrade to 997.1 ..Grerat info, takes me 3 days read all info.. then i have question. My car is 997.1, no bose but PCM 2.1 with navi, cd charger,PCCM plus,ASK amplifier. I just buy this 997 Porsche Classic radio in USA and i see one ,at least difference for EU version. I dont have this packet this FM signal amplifiers. My question is , can i get it somehow working without them? If not,where i can buy them?
Thank you in advance ..Br.Juha
#2331
Juha Pussinen (02-18-2024)
#2332
UP..Please if someone can asnwer i would be happyyy
HI All, First thank you so good forum and info for this upgrade to 997.1 ..Great info, takes me 3 days read all info.. then i have question. My car is 997.1, no bose but PCM 2.1 with navi, cd charger, PCCM plus, ASK amplifier. I just buy this 997 Porsche Classic radio in USA and i see one ,at least difference for EU version. I dont have this packet this FM signal amplifiers.
My question is , can i get it somehow working without them? If not, i can buy them?
#2333
Yes, I got the same behavior when I first switch on my new unit. In the PCCM+ configuration settings, there is an option to turn off the 'daytime running lights' (I believe is a check box) if you remove the check, the car goes back to its original headlights operation.
#2334
Just want to post my installed unit. This is an amazing upgrade that I'd highly recommend. This is the ultimate setup for me.
Found the right shop who removed and had the bezel painted. I brought them all the parts and gave instructions I collected through this thread and others and the install works perfectly. Added the xm antenna, the jgoga wire to send usb out the back, the wireless carplay adaptor tucked back behind the unit, and a reverse camera from Amazon. I tried doing the alibaba reverse usb wire and the shop had an issue with it. The jgoga wire was plug and play so I'd recommend going that way. I didn't need power out the front as I had already installed a magsafe charger onto a rennline mount.
They mounted the microphone that came with the unit on the top left of the windshield. It's pretty small and out of the way so I'm not mad at it's location. I hate seeing wires. It works very well with the top up but have not tried the top down. Didn't know enough about the mod to install it into the steering wheel but might have had shop try it if there was more information/instructions.
The following 5 users liked this post by midcont:
C2 Turbo (06-01-2024),
myw (03-13-2024),
Spastblast (03-13-2024),
Sporty (03-13-2024),
TerrestrialFlyte (03-13-2024)
#2335
#2338
The shop is Extreme Motorsports on Rt. 4 in Paramus. Speak to John the owner. He is well versed now on installing this unit the right way.
myw (03-13-2024),
Ohio Performance (03-14-2024),
Spastblast (03-14-2024),
Sporty (03-14-2024),
