Mezger turbo!
Old 06-26-2021, 05:57 PM
  #331
jaredomin
jaredomin's Avatar
Old 06-26-2021, 06:46 PM
  #332
bschurr
bschurr's Avatar
Please follow the specified installation instructions for the center cap and align the point at the bottom of the Porsche crest to point directly at the valve stem. Thank you.
The following 3 users liked this post by bschurr:
jaredomin (06-26-2021), jayhawkai (08-20-2021), PowderJunkie (06-27-2021)
Old 06-30-2021, 12:52 PM
  #333
jaredomin
jaredomin's Avatar
Checked the battery and results came back within spec. So, now its time to check for boost leaks. After that its time for data logging and tuning.
Old 06-30-2021, 01:06 PM
  #334
jaredomin
jaredomin's Avatar
New daily alert. Who doesn't love a good stripper? #lawnmower
DocR (06-30-2021)
Old 06-30-2021, 02:44 PM
  #335
ky13
ky13's Avatar
Have a soft spot for 96-00 hatchbacks.
The following 2 users liked this post by ky13:
DocR (06-30-2021), jaredomin (06-30-2021)
Old 06-30-2021, 07:24 PM
  #336
cdk4219
cdk4219's Avatar
Originally Posted by jaredomin
all of them come back, unfortunately.
that’s a wide array of reoccurring faults,as said above I would be looking for sawzalled or disconnected grounds/ connectors.
Old 07-01-2021, 11:58 AM
  #337
ejabour
ejabour's Avatar
Lol
Old 07-02-2021, 10:52 AM
  #338
Alex Wink
Alex Wink's Avatar
I imagine no one is surprised this thing runs like ****
Old 07-09-2021, 10:43 PM
  #339
jaredomin
jaredomin's Avatar
Where can i find the proper fuse box diagram for my car?
Old 07-09-2021, 10:48 PM
  #340
Petza914
Petza914's Avatar
Received 6,611 Likes on 4,202 Posts
There should be a sheet of paper inside the clips of the fuse box cover. I assume that's not there? I don't know or the owners manual includes a list of the fuses and numbers or not.
Or how's this - https://www.renntech.org/topic/32535-997tt-does-anyone-have-a-diagram-of-the-fuse-panel/
Don't remember what year yours is.
Old 07-10-2021, 02:46 AM
  #341
Castro
Castro's Avatar
Old 07-11-2021, 02:25 PM
  #342
jaredomin
jaredomin's Avatar
Originally Posted by Castro
isnt that for a c2? Are they the same?
Old 07-12-2021, 05:32 PM
  #343
jaredomin
jaredomin's Avatar
Starting to think my car was fcked with while it sat at that local shop. None of the fuses light up
any one have a list of ground locations for this car?
Old 07-12-2021, 06:32 PM
  #344
Petza914
Petza914's Avatar
So, the car runs but none of the fuses show power or are you checking continuity. It looks like one side of the test light is connected to the negative battery terminal. Is the other side the test probe end. You won't get ground continuity at the fuse contacts. The fuses break the power circuit.
Old 07-12-2021, 10:26 PM
  #345
jaredomin
jaredomin's Avatar
Look at that right back where we started
Quick Reply: Mezger turbo!
