Cheap Android Head Unit Review!
#1171
What is important with the processor is how many cores it has. Older HUs use quad-core (4) processors, but they have now been superceded by octa-core (8) processors and my advice would be to not consider a quad-core at all. Go for an octa-core processor. The UIS7862 is a great octa-core, modern processor which will easily run your HU and Android Auto or Carplay if that is how you intend to go. The 7862 is is very fast and will give you a really smooth Android experience. A good alternative would be the UMS512, which has similar performance and benchmarks as the 7862.
So what you should be looking for, ideally, is 8 GB/128 GB with a modern octa-core processor such as the 7862 or an equivalent.
#1172
Important things to take into account are the amount of RAM, amount of storage and the type of processor in use. You will need a minimum of 4GB of RAM to run your HU smoothly and to give it an element of future-proofing (as most apps require more grunt as they develop over time), but I would recommend 8 GB, which doesn't cost much more and will serve you well for years, allowing you to run the latest, complex apps and to multi-task. For storage, it will depend on how much you intend to load onto your HU. 64 GB would be my minimum, but I would go for 128 GB if possible - you will never run out of space with 128GB.. So I would look for 8GB/128GB if possible.
#1173
minuit997 (01-17-2024)
#1174
Am I correct in assuming that in a 997.1 with Bose I will have to splice into the car harness to get power? There's no other way of doing it? I'd rather not touch the OEM harness at all.
#1175
no, there is no modification of the OEM harness required. You need to splice into the adapter harness between the HU and OEM plug (the harness that comes with the HU) in order to power the MOST adapter, but that's it.
#1176
#1178
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/1123x767/23_01_2024_11_00_02_949c8766bfd47324200d024492ea48bbebd18cc2.png)
smrpr (01-23-2024)
#1179
Okay, so, for my 997.1 Carrera with Bose, will be mostly using Carplay and don't need a rear camera:
- I need to buy a 7862 processor based head unit as it allows for more tinkering than the other processors.
- I need to turn the volume all the way up before removing the original head unit in order to have proper volume levels when I install the new one.
- I need to buy a dual fakra adapter in order to not lose radio signal as there is only one plug with the kit.
- I need to buy a converter to use the original GPS antenna in case I want to.
- I need to order a version with the extra MOST adapter
- I need to 3d print some adapters in order to secure it properly.
Am I missing something? From what I understand, Heregoes and Owtowsin stores sell the same product but with different processors, right?
#1181
Short answer:
Yes, yes, yes, yes, yes and don't know as I don't have this unit personally.
Slightly longer answer:
The important thing about the processor is that it has 8 cores and as much RAM as you can get. Octacore, 8Gb/128Gb is as future-proof as you can get right now. 7862 is a good, modern, fast processor.
Turn volume up to 75% on the PCM seems to be the most recommended. I did it that way and sound is perfect.
Get the adapters for radio and GPS from Amazon for a few dollars and then you can exchange them easily if they happen to not fit.
Good luck with the install!
#1182
- you also need to (or at least should) bypass the stock antenna amplifier, just like you would with the PCCM install. You'll need a dual FAKRA M-M cable, 6" or so long
myw (03-22-2024)
#1183
- you don't need to 3d print adapters, you can simply space out the mounting rails with some washers to make it fit more securely
I think that cable is what I mention in my third bullet point? Or something else?
Like this one?
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/299x500/_12_7009f3b4e10fbaecba31cf7fe942475ba68cacbe.jpg)
#1185
My only complaint with the unit is the built in microphone. Unlike previous units, this one does not accommodate an external mic. I am difficult to hear on the other end (like I'm in a tunnel) but It's a small annoyance since mine is a cab and talking on the phone is a challenge regardless. I simply let it go to vm - I don't want anything to interrupt my drive!
