Cheap Android Head Unit Review!
Old 03-22-2023, 11:17 AM
  #766
myw
myw's Avatar
Originally Posted by RLR997
997.1 Turbo Tiptronic/Auto
In north america , the .1 pcms have 2 fakra antennas. Both need to be connected hence a dual fakra antenna adapter.
As for direct connection of the antenna I cant recall the specifics but I do have several posts in this thread above (july / aug 2021) where I carefully + thoroughly. went through the exact connections for both bose as well as the antenna adapter. But there is a blue cable acc antenna cable out of the harness that taps right into the fakra adapter.
Old 03-22-2023, 12:26 PM
  #767
Jabamusic
Jabamusic's Avatar
Default Please bear with me, but help if you can
I have now found sometime to set aside for this installation and could do with a bit of guidance….
The car is a 997 Gen 2 PDK . No BOSE.
New HU
The dual Dakar supplied by Owtowsin
Current connections
Only 1 pin!!?
As you can see I have removed the old PCM leaving me with these 3 plugs, none of which I seem to be able to reuse. Unfortunately I can’t remember which is the GPS, the radio etc. can anybody help with that?
The new Dual Farrakhan which has the Din socket on the other end will not connect into either one of the in-car plugs as it is keyed with a part in its moulding.
My next doubt is the main connection block.
it does connect to the one provided with the new HU but cants at an angle slightly as there are no adjacent female slots (on the car block) for the male pins (of the new adapter) to slot into. It appears to me that there is only 1 pin that the new adapter connects to and that can be seen in the photo above!
is that right?
Weirdly, I did a test install and the HU works with full sound and function ( as much as I could test) as It used me a it’s antenna as I didn’t have an aerial connected and I did not try navigation, or Dab etc as they were not connected either.
Can anybody tell me what are all the other male pins on the new block doing if there is only 1 pin connecting it to the car’s wiring harness?
I have other questions like routing and placement of the front and rear cameras etc, but I won’t press my luck and all your patience (just yet).
Many thanks to you all in anticipation
Jaba
Old 03-22-2023, 12:44 PM
  #768
Graufuchs
Graufuchs's Avatar
Received 1,280 Likes on 476 Posts
@myw
What is the best way to wire in the MOST adapter?
Old 03-22-2023, 09:32 PM
  #769
RLR997
RLR997's Avatar
Originally Posted by Graufuchs
@myw
On the harness that came with the stereo, I 'unpinned' them, soldered them to these, then repinned them into the harness. If you look at the diagram on the unit or in the box it will show which wires lead to which pins
Graufuchs (03-23-2023)
Old 03-23-2023, 04:10 AM
  #770
RLR997
RLR997's Avatar
Sorry I am an idiot, I'd already figured out the blue cable (only realised after pulling the unit out!).
As for the Fakra, I have 2 (total) are these the black and yellow. I was under the impresison the yellow one was the PCM GPS antenna, are these the two you have within the dual Fakra? I have the single one and the AM/FM is OK but not great.
Old 03-23-2023, 06:27 PM
  #771
myw
myw's Avatar
@myw
there is a post written by myself in this thread approx july/aug 2021 - with exact instructions re this - i recall i titled the post clearly as well.
Since I can't edit the post on this thread, I am going to update the 997 retroFit post with instructions, I can tag you there but you have to be a part of the forum first. Pm me your name and i can tag you np.
With that said, i can only guarantee that it works with private line of android radio, as the public stuff, uses nonStandardized pin harnesses wiring etc etc.
Old 03-23-2023, 06:30 PM
  #772
myw
myw's Avatar
Dual fakra is black + yellow for the .1 cars - i had no idea the .2 cars have dual fakra antennas (from what i recall the north american ones do not). I believe the GPS info (for the .1) is all carried thru the canBus, there is no direct gps connection for the pcm 2.0. Now I am not sure about the pcm 3.0 however.
From your photos I only see a Black Antenna cable - there is no Yellow (dual) fakra antenna. Blue is GPS i believe - which you .2 guys can likely reUse provided an adapter
Amazon Amazon
RLR997 (03-23-2023)
Old 03-23-2023, 06:31 PM
  #773
myw
myw's Avatar
can those blue Covers covering all those pins be removed ?
its not 1 pin, not even close to that. power, gnd, acc, 2 canbus pins, etc all connect - but ur quadlock harness is covering them .
New HU
Current connections
Only 1 pin!!?
Jaba
Old 03-24-2023, 05:16 PM
  #774
SIM9er
7th Gear
SIM9er's Avatar
The female pins go past those blue covers, one can slide out, the other does not - but no need. That stumped me when I first looked at it, pressed the connector together with the covers in place and it worked.
Old 03-24-2023, 05:45 PM
  #775
Jabamusic
Jabamusic's Avatar
I’m glad I’m not the only one to be a bit (a lot) confused by those blue covers over the pins. As you say SIMer, the HU works comewhat may.
Old 03-24-2023, 06:27 PM
  #776
SIM9er
7th Gear
SIM9er's Avatar
Oops I meant to say the male pins go past the blue covers! With no manual and minimal experience it was a bit experimental for me.
Old 03-25-2023, 12:56 PM
  #777
OmairK
OmairK's Avatar
@myw, do you know if there is a new version coming up? Trying to get an upgrade for my 987.2 CDR30 with Bose.
Old 03-26-2023, 04:26 AM
  #778
Jabamusic
Jabamusic's Avatar
MYW - The sole pin I was referring to is the single metal one seen in photo 3 at the top coming out of the multiple holes. Can you explain a bit more when you say that the Quadlock harness is covering them?
What confuses me is why there are the blue plastic covers on the
quadlock. They do not appear to move when the quad lock is connected or does it happen when it is engaged?
but as SIMer says, the HU works, but how ?
Old 03-27-2023, 12:20 PM
  #779
DocNik
DocNik's Avatar
Default Got mine in.
Done! It looks good and sounds good. Back up camera works. It was a bit nerve wrecking to run the cables, but easier than I thought. My only problem is not finding FM stations under about 99 MHz. Only got a single FAKRA connection in the box, so I tried a double FAKRA, but that killed all sound, in all apps. Not sure how or why. Went back to the single FAKRA. I can live with that.
Mounted a spare SIM-card and now it accesses the internet on its own.
Thanks for all your help, Michael Wong!
myw (03-27-2023)
Old 03-27-2023, 02:19 PM
  #780
myw
myw's Avatar
The blue covers are obviously moving when the quad lock harness is engaged - otherwise no power or sound. Power/GND/ACC/canbus is on one portion of the quad lock while the speaker audio are on another portion. The single blue pin that is exposed IRRC is the antenna ACC pin (or the amp pin)
What confuses me is why there are the blue plastic covers on the quadlock. They do not appear to move when the quad lock is connected or does it happen when it is engaged?
Quick Reply: Cheap Android Head Unit Review!
